Question about SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Loading songs i have been trying to load songs forever, but every time I turn it on, it goes " uh oh!" Please help, it's my only Christmas present and it won't work.:(
  • Tiger2014 Dec 25, 2008
    someone help please...
  • 3 Answers
Check the file types from you music the shaker only plays MP3 and PCM WAV  file types. You may have WMA (if u used windows media player) which will not play on the shaker  (i had this same ploblem btw) you can easly find free music file converter software to change these files to mp3 or wav types (which i did), or you could rerip to songs from a cd and tell the windows media player to rip the files as mp3 types instead of the default wma format  from the windows media player widow :
tools >> options >> Rip Music >> under format select mp3 (theres a wav option but i used the mp3 option to be safe)
do not use the sync feature it will automatically convert your files to to wma (why? i dont know) instead copy the files directly from the folder that contains them :
right click the file you need to put on the player select open file location drag and drop to the player (or copy/paste if you want).
hope this helped =P
Posted on Dec 31, 2008
    Problem Solver:
  • 3 Answers
Did you put your sd card
Posted on Jan 03, 2009
The machine has overheated and all I get now is the light and the fan turns for a couple of seconds then goes off.
uh oh. you could try and clear the cmos and see if you can erase the error code. do this by removing the battery and holding down the power button for 30 seconds. the uh oh, is because you may have damaged the cpu. hopefully not!
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 12, 2011 | Acer Aspire 5535-5050 Notebook
I starts and tehn stops and beeps three times. I can start it aain and it will run but then it does the same thing'
TYhe iRobot Roomba has different model designations. Here is a webpage with a list of what the beeps mean in the 400 series. I am thinking that is what you have. 3 beeps means the dirt cup is dirty, filters are dirty, or debris in collecting and it needs to be cleaned.
Here is the webpage: http://uksupport.irobot.com/app/answers/detail/a_id/1047/kw/iRobot%20Roomba%20Discovery%20SE%20Bagless%20Robotic%204200%20series%20Vacuum%20beeps%203%20times/related/1
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | iRobot Roomba Discovery SE Bagless Robotic...
It starts and for a few seconds and then stops The battery is fine
Is the charging ase turned on and is the dust container emptied? Any obstructions?
Apr 11, 2010 | Roomba Robotic Floor Bagless Vacuum
It keeps saying uh-oh uh-oh?
im trying the same thing and mine does the sme thing its crazy
Jun 17, 2009 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Can not charge thr battery
bbaker58,
When you press the "clean" button after charging, does the Roomba give you any audible tones? Those tones are the key to understanding failures in the 400 series. See chart below to decode those tones
If you get no tones at all, then either (1) you're not getting power from the battery to the main circuit board or (2) the main circuit board is dead. You really have to open the unit up to figure out which it is. Circuit board replacement is a pretty involved procedure since it requires disassembly of almost the entire robot. If you are brave and want to try it, replacement PCAs are available from places like www.RoboticVacParts.com. They are my favorite shop because they sell parts tha iRobot refuses to sell to consumers and they're prices always beat what iRobot charges.
Roomba Says
What It Means
What You Should Do
Plays 4-note song as Power button blinks RED
Play sound The battery is low and needs recharging
• Connect the robot to the charger or Home Base® and recharge the battery. “Ehh”
Play sound The Cliff Sensors are dirty or malfunctioning
• Pick up your robot and turn it over.*
• Check for any debris that might be caught underneath the front bumper, around the Cliff Sensors.
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out.
"Uh-oh"
A wheel is stuck or is not touching the ground
• Lift the robot and place it down again.
• Press the Clean button to restart the cycle. “Uh-oh” plus 1 beep
The robot's main brushes are stalled
• Pick up your robot, turn it over* and remove the wire guard.
• Look for something blocking the brushes; you may need to remove and reinstall the brushes to remove the obstruction. “Uh-oh” plus 2 beeps
The robot's Side Brush is stalled
• Pick up your robot and turn it over*
• Check to see if something is wrapped around the Side Brush.
• Remove the Side Brush with a screw driver and check for string or hair wrapped under it.
• Replace the Side Brush, place Roomba in the center of the room and press Clean to resume cleaning. “Uh-oh” plus 3 beeps
The robot's vacuum is stalled
• Remove and empty the Dirt Bin.
• Use a flat-head screwdriver to remove the grill at the back of the Dirt Bin.
• Spin the Vacuum Impeller around, shaking out any debris that may be stuck.
• Replace the grill and the Dirt Bin. “Uh-oh” plus 4 beeps
Play sound
The robot's Drive Wheels are stalled
• Your robot may be stuck, or something may be caught in a wheel.
• If it's stuck, place it in the center of the room and press Clean. It should resume cleaning.
• If it is not stuck, lift the robot, turn it over* and look for something caught in the wheels. Test the wheels by pushing them in and out and making sure they rotate freely. Place robot in the center of the room, press Clean, and it should resume cleaning.
If this continues to happen every time you clean, you may need a software upgrade. Contact iRobot Customer Support.
“Uh-oh” plus 5 beeps
The robot's Cliff Sensors are obstructed
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out. “Uh-oh” plus 6 beeps
The robot's Wheel Drop Sensors are overloaded (robot is stuck in a bumpy area)
• Pick up your robot, place it in the center of the room, then power it off and then on again.
• Select the cleaning cycle you prefer and let it go to work.
“Uh-oh” plus 9 beeps
The robot's Wheel Drop Sensors have failed at startup
• This failure requires you to contact iRobot Customer Support. Click here to send us an email. “Uh-oh” plus 10 beeps
The robot's bumper is not registering obstacles
• If the robot travels for a long distance without bumping into anything (which would be unusual), it might think it’s stuck and can’t move; press Clean again and it should resume cleaning.
Jun 02, 2009 | Roomba Robotic Floor Bagless Vacuum
"uh oh"
this sounds like 3 problems
1 battery power
2 upgrade software back up files
3 corrupted files
May 20, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Error message
Uh oh.. Time for a service visit as the optical assembly has stopped scanning properly...accordianman
Mar 21, 2008 | TruTech TT320
Sansa shaker not playing
Funny I found this forum because I've been having the same problem. My understanding is that subscription services (yahoo music, iTunes, etc.) don't come in an mp3 file format. You can, however, add songs from cd's you own.
Here's a link you might find helpful. It's from the Sansa Forums. One of the posters describes how you can convert files. I don't know how complicated it is. Good luck! :)
http://forums.sandisk.com/sansa/board/message?board.id=shaker&thread.id=121
I understand your frustration! I've been having the same problem. I just wasted TWO HOURS trying to get music to download onto this Shaker. The extra $40 for a better device would have been worth it! I can't afford to buy all the cd's that I'd need to fill this player with the songs my son likes. I'm thinking of bringing it back!
Dec 18, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
"uh oh"
The music has to be in MP3 format.
If you have copied CD's to your computer, you will need to change the settings in Windows Media Player to copy them as MP3's.
Windows Media Player>Tools>Settings>Rip Music (Copy Music)>Chane Rip Music as to MP3.
Delete all the songs you copied before from your computer and from the Shaker.
Copy the new songs back to the Shaker after you change the settings.
Best of Luck.
Oct 16, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sandisk 250
ok this is weir this exact same thing happened to me this morning and i was on here looking for help and i came across your post i also went to ten sandisk website and found some helpful info. i just tryed it and my player is fine so what you have to do is take the back off of your player the four screws need to come out then take it off and you will see the battery it looks just like a cell phone battery take it out and put it back in its simple then your player should turn on. let me know if i was helpful my email is applebottem_ME@yahoo.com
Mar 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Shaker SDMX9N-512 MP3 Player Logo
179 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
