Question about Acer Extensa 5620-6119 Notebook
Add internal blue tooth to Acer Extensa 5620
I am searching for the internal Acer Blue Tooth unit to go inside my Acer Extensa 5620 which did not come with the feature but has the light on front indicating other models must have the feature.
    Master:
  • 461 Answers
Most inexpensive upgrade would be to purchase a bluetooth USB plugin.
Posted on Dec 26, 2008
My laptop acer extansa 4620 has a bluetooth button near front speaker but it can't woring. And no blue tooth options on os control panel. What will i do to on bluetooth
when you just turn on before windows loads hold your finger on the blue tooth button keep your finger on it until windows completely loads you should see the Bluetooth light up and it should working now
have a great day and always welcome sir .
May 29, 2011 | Acer Extensa 4620 Notebook
My machine (Acer Extensa 4630 Z) blue tooth is not working. OS is Windows XP. Could u pls send me the required Drivers or information regarding this case. BR, Ruwan
This is the link to your bluetooth driver.
http://global-download.acer.com/GDFiles%5CDriver/Bluetooth/Bluetooth_WIDCOMM_5.0.1.1400_XPx86.zip?acerid=633640461748020381&Step1=Notebook&Step2=Aspire&Step3=Aspire%201640&OS=X01&LC=en&SC=PA_6
May 29, 2011 | Acer Extensa 5620-6119 Notebook
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
How to use bluetooth device in acer aspire 5745.
first the blue tooth device need to be installed , meaning to have the driver for the device ...after that from the blue tooth button you turn it on ..and the device could be find on any other device with blue tooth and be chosen to receive data ..the same way arround..if you open the blue tooth ..you can search for devices ..and choose data to send to devices found in the area..
Oct 01, 2010 | Computers & Internet
I have a bluetooth button on my laptop but my bluetooth dont work?. when i press the button it says "no device" what shall i do ?
This laptop is blue tooth capable, but has no internal blue tooth adapter.
You will ether have to call acer and see if their help desk can answer your questions, or purchase a USB blue tooth adapter
Jan 17, 2010 | Acer Aspire 5500 5570-2609 Laptop
How can I operate bluetooth on my acer laptopextensa 4630
First you need to install the bluetooth driver software [that can be found on the acer CD that came first time with your laptop or just look here www.acer.com ] , then reboot your system . after that turn on the bluetooth buttons on your laptop and on the device you want to connect your laptop with for example [Cell phone ] . make on of them look for the other . then you need to pair them , so that you don't need to do that again .
Just look around in the software that you already installed and problem will be solved .
your rating is very important for me , that's why I've helped you .
good luck .
Jan 12, 2010 | Acer Extensa 4620 Notebook
I have a laptop but dont know how to use the bluetooth
which model of the extensa? very few laptops have built in blue tooth..
Apr 26, 2009 | Acer Extensa 5420-5687 Notebook
How can i enable the bluetooth in acer extensa5230
ur blue tooth driver is not installed properly....go to controle pannel....click on add new hardware...then add ur blue tooth device and provide path of cd to install it
Mar 10, 2009 | Acer Extensa 4620 Notebook
CAN'T USE BLUETOOTH
you need to install blue tooth drivers/application first. then you will able to use it.
Dec 01, 2008 | Acer Extensa 5420-5687 Notebook
How do I turn bluetooth on and connect a Mobile phone to a Acer Aspire 5710G
Windows Mobility Center includes Acer-specific settings like Bluetooth Add
Device (if applicable), sharing folders overview/sharing service on or off, and a
shortcut to the Acer user guide, drivers and utilities.
To launch Windows Mobility Center:
Start Windows Mobility Center from the Control panel
Start Windows Mobility Center from the Accessories program group in the
Start menu
You should be able to turn on blutooth from there.
Please let me know if this helps.
Mar 17, 2008 | Computers & Internet
Acer Extensa 5620-6119 Notebook Logo
222 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
