Question about Champion G5NG853S Household Juice Extractor
Motor not working
Plugged the juicer in and no sound in the motor at all. No smell of smoke. Opened the bottom and nothing suspect. The juicer is about 2 years old and not used very much.
  • 1 more comment
  • vgbailey Dec 30, 2007
    I have the same problem with my Champion... It was working perfectly 3 wks. ago. After cleaning it, I put it away as usual. Today went to switch it to "ON" and got absolutely nothing. Granted, my machine is at least 10 yrs old. However, I was at least expecting some noticable noise or maybe a funny smell. Instead, its worked perfectly up to this point - I can't believe it!!!
  • Ken Foster Apr 01, 2008
    Plugged the juicer in and it doesn't work. There is no smell of anything burned. It was working and then it stopped.
  • Anonymous Apr 26, 2008
    no power when you turn on
  • 3 Answers
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
Posted on Aug 16, 2007
Had same problem cleaned the shaft lightly with steel wool and put all together and it worked perfectly
Posted on Jul 11, 2010
Juicer does not turn / rotate. Does this mean the motor is burnt out ?
It could mean burnt motor, but it could mean that it's simply got gunk in it, and it needs cleaning/lubricating. You'd have to take it apart to tell. A burnt motor has a very specific smell. If you take it apart, and there's no burnt smell, likely cleaning and lubricating will fix it.
Jun 10, 2015 | Braun MPZ-22 Juicer
No longer turns on
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Mar 25, 2014 | Waring JEX 328 Health Juicer
Motor may be burned out; juicer does not turn on
If you saw smoke, likely the motor may be burnt. A bit late!
Mar 23, 2014 | Waring JEX 328 Health Juicer
My Omega 1000 is 10 yrs old, but I've only been using it regularly for 1 yr and 3 months. Putting a carrot through isn't stabilizing it anymore. It takes off when the screen is 1/2 full. But the weirdest...
Yes the blade is hitting it when the juicer vibrates
severely. I have an Acme, 21 years old, and found
very difficult to control vibration especially with a
new shredder blade. If you are handy this is what
to do. Order a new cover from omega, cover design
has changed so you will need the plunger also. This
may sound incorrect, but you will have to use a small
file to file down the cutting burrs on the blade a fraction
of an inch. Then with the juicer fully assembled, unlock
the set screw on the center of the bottom and turn it
clockwise until the chute contacts the blade then back
it off a half turn. Now the chute to blade gap is set
correctly. In filing down the burrs you make the blade
a little duller but you also narrow the gap and feed
the produce through more slowly and evenly. This
comes from 21 years of using this machine. With
a new blade I could not control the vibration no matter
how I fed the thing. If this sounds a bit too much get
rid of the Omega and try the pulp ejecting type. The
Miracle MJ1000 is a nice little juicer for about $130.
Jan 29, 2011 | Omega 1000 Juice Extractor
The motor stopped while juicing hard veggies and doesn't work any more even after the engine cooled down. again. How to fix it?
There may be an overload switch somewhere on the unit, it will just be a small button projecting from the underside most probably or in a small hole. If there is, just depress it. If the unit actually burned out yu would have seen smoke and smelled it.
Jan 21, 2011 | Breville BJE510 900 Watts Juicer
When we juice, it turns and moves across the counter
Both the Omega and Acme juicers vibrate no matter what you do. I found a worn shredder
blade actually produces less vibration. However this involves filing the cutting burrs down
and resetting the blade to chute gap. If you're up to it, take the blade out and file each row
of burrs about halfway down. Then with the juicer fully assembled, unlock the set screw on
the center of the bottom, turn it clockwise until the chute contacts the blade, and back it off
a half turn. The set screw actually raises and lowers the motor spindle. Both companies
would not agree with this, but this solution comes from operating my 21 year old Acme.
I recently replaced the blade and the juicer immediately began tap dancing. Went back to
the old blade.
Jan 16, 2011 | Omega 1000 Juice Extractor
My Acme supreme juicerator #6001 trips off several times before I can complete the process of juicing in order to get an 8oz. glass of juice. The motor spins smoothly, no vibration at all.
There is a reset button on the bottom of the
juicer. You will have to separate the base
by removing the 4 bottom screws and adjust
the sensitivity of the reset button turning the
small screw on it. Sorry, but forgot which
direction increases or decreases this. Had
to do it on my 21 year old Acme because of
the same problem.
Apr 22, 2010 | Acme 6001 Juice Extractor
The engine started to make a horrible noise and practically jumped off the counter while it smelled like something burned.
these juicers have a tiny little motor. once they smell bad, they are shot. not worth repairing. Joe
Mar 04, 2010 | Jack Lalanne Power Juicer 250 Watts
Champion G5NG853S Household Juice Extractor Logo
767 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
