PROBLEMS WITH MULTIPOINT
MY RED MULTIPOINT MOVES UP AND DOWN BUT NOT SIDE TO SIDE TO LINE IT UP WITH THE CROSS HOW CAN I FIX THIS
  • 2 more comments
  • mulac Dec 26, 2008
    it is a phillips make and model is 55pp35217 the chassis# i dont know
    i tried wat u mentioned about the convergence pattern i turned off tv put in the numbers it didnt turn on is there anything else i could u
  • mulac Dec 28, 2008
    my problem isnt getting into the menu its when i get into the red multipoint to line up the crosses the red one wont move side to side it just goes up and down
  • ladywinn
    ladywinn May 11, 2010
    What is the make-model# and chassis# on back of TV ?
  • 5,138 Answers
Ck around your STK ICs these are your convergence ics you may have some low ohm resistor open/bad .Have you replaced your STKs ?
Posted on Dec 26, 2008
  • 3 more comments
  • ladywinn
    ladywinn Dec 26, 2008
    Try This with set off Press0-6-2-5-9-7-Status with for set to come back on if this works you should be in convergence settings try to adjust Now.
  • ladywinn
    I meant to say Wait and see if set comes back on with convergence pattern.
  • ladywinn
    Do the same as before except Press 0-6-2-5-9-6-Status
    WITH TV ON.
    (3) Press Menu with remote while menu is still up Press 0-6-1-5-9-6 or 0-6-1-5-9-7 use left/right arrows to to select what you want to adjust ,use up/down arrows to adjust .
    (4) Enter 1-6-2-5-9-6 then Menu or 0-6-2-5-9-7 then Menu (one of these should get you into convergence)
  • ladywinn
    ladywinn Dec 27, 2008
    Has any of the information got you into service menu?
  • ladywinn
    ladywinn Dec 28, 2008
    Go back to STKs convergence ICs you have a Resistor bad CK low ohm ones 1.5ohm -2.7ohm-3.9ohm
Is there a code number that needs to be entered to bring the convergence pattern or menu on screen.
From a user standpoint you would follow these steps to bring up your Convergence menu:
1) Press your MENU button.
2) Press the Right Cursor Button to enter the Picture menu.
3) Press the Down Cursor Button until you highlight the MANUAL CONVERGENCE choice on the menu.
4) You will then see the following choices on the right hand side of the menu: Convergence Red, Convergence Blue, Multipoint Red, Multi Blue, Save Multipoint.
5) Once you choose either the Red or Blue choices you will get a crosshair in the middle of your screen. You will then use either your Up, Down, Left, or Right Cursor buttons to get the two images to line up correctly. If you still have multi images on your screen in either Red or Blue you would then have to adjust the Multipoint choice for that color.
May 14, 2011 | Philips 51PP9100D 51 in. Television
Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
To process and save the adjustment made, follow the steps below;
  1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  2. Enter the menu on your TV. Use the remote control and bring up the menu.
  3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  5. Press "Enter." A crosshair pattern will appear on your screen.
  6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  9. Repeat these steps for all colors.
Take care
Jul 06, 2010 | Televison & Video
Red cross won't line up with white and blue . The red will go side to side but not down???
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Cannot adjust red multi point
Symptom:
Unit appears to have poor convergence due to:
1. cross hatch appears tilted
2. one color (or more) being larger than the others.
Cause:
The yoke or yokes may have:
(1) rotated slightly or
(2) slipped down during transport.
Resolution:
Loosen a yoke and lower to inspect the tape. If black tape is present remove it from under all yokes (white tape or no tape is OK). Slide yoke or yokes up tight against the CRT and tighten to prevent slipping or rotation. Precede with
alignments and or convergence as necessary.
Jul 29, 2009 | Philips 60PP9202 60" Rear Projection...
I have a yellow line on the right side of my Toshiba 50 rear projection TV and yellow shadows around people
It sounds like a convergence problem---go into the customer menu and select convergence---set should offer center and multipoint adjustment--in the multipoint look to see if the outer crosses adjust--if red or blue will not adjust somewhere--bad convergence IC's.
Jul 17, 2009 | Toshiba 42H83 42" Rear Projection...
Remote will not adjust red convergence/multi-point horizontally
check resistors around convergence i.c.(red) philips may use 2 resistors in parallell. should be about 1.8 ohms. assuming you already changed the i.c.
Jan 17, 2009 | Philips 55PP9352 55" Projection Television
UNPLUGED TV REPLUGED IT AND THE COLORS ARE WAY OFF AND CAN NOT ALIGN THE RED CROSS TEE,,,MOVES UP AND DOWN BUT NOT SIDE TO SIDE
This is a problem with the convergence circuit. If you can solder, you can fix this yourself. Please update this with the make and model of the set so we can provide details.
Thanks,
Dan
Jul 28, 2008 | Televison & Video
Blue Multipoint converge failure Philips 55PP9753
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2008 | Philips 55PP9753 55" Rear Projection...
PHILIPS 50P8341 60 IN.
Check the other posts for convergence problems. This may be what you're experiencing. Have you tried bringing it in with multipoint convergence? It's under Menu -> Picture -> Manual Converge -> Multipoint Red and Multipoint Blue.
Dec 07, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
