Question about Daewoo DVG-9200N DVD Player
DVD will not load
I just moved my dvd player on long trip on a truck and even though I packed it quite well when I load a dvd all that happens is the player says loading. After a little while the player gives me a "no dl sc" error message. Anyone know how to resolve this problem or shoudl I go buy a new player? Thanks!
    Master:
  • 416 Answers
Firs try to clean the lens with CD/DVD cleaning disk (it might be $1-5 depending on store)
Also check if DVD disk not upside down.
Also chek the DVD disk for scratches
Good Luck
Posted on Dec 25, 2008
I have a samsung dvd-v4600...and when i put the dvd disc in it just keeps loading and will not load ..what do i do to fix this?
Does it do with original DVD or copied DVD ?.
if the original one works fine but the others not, your DVD may not capable of playing copy -R/RW discs..even though your DVD specs says: Plays DVD-Video, video-mode DVD-R/RW and DVD+R/RW, CD-R/CD-RW, MP3 CD, Kodak Picture CD, and JPEG image CDs, sometimes this happens due to bad recording of DVD .Try to use better recorded DVD or if possible use the original ones..
Thanks in advance for rating me..Regards
Oct 22, 2010 | Samsung DVD-V4600 DVD Player/VCR
Why does my player display
Sorry, the player is dieing. i had this player with the same problem.
Jul 05, 2010 | Cyberhome CH-DVD 300 DVD Player
I keep getting a Bad Disk error when loading DVDs that I know are fine. When there's no disk loaded, all I see is the blue load screen with the message "loading" in the upper left
there is a ribbon cable in the DVD player that connect the moving laser head to the main circuit board. When this cable becomes damaged from moving over time, it will claim that your DVD is bad (even though it is not). Best to scrap the player and buy a new one.
Oct 07, 2009 | Cyberhome CH-DVD 300 DVD Player
The dvd player doesn't play the dvd's
when i load the disc it spins for 5-7 seconds then quits and the poer light, play light and loading light flash continously. model p421
Apr 18, 2009 | Televison & Video
My MUSTEk MP-100 does not load avi (DVIX/XVid) files
The player actually loads divx (.avi) format files. It does not loads some .mp4 format files.
Jan 23, 2009 | Mustek MP100 Portable DVD Player
Dvd reading
I had the same thing happen to a used DuraBrand 7" Portable DVD Player. Check and see if the laser transport is locked in at the top of the track -- which would be in position to read the outer edge of the DVD. The laser transport gets locked into this position and you get "no disc" error messages.
I removed the bottom of the DVD player -- a matter of seven screws -- and moved the laser transport by hand nearer to the center post of the DVD turntable. This cured the problem and my DuraBrand is working fine now.
I have no idea what makes the laser transport move to the extreme outer position and get locked there, but this solution works. Good luck with your own.
Jun 25, 2008 | Durabrand DUR7 Portable DVD Player
Can't play dvd
Maybe your dvd got some capacitors dried on the power supply.
But you can also clean the laser lens maybe is dirty.
Jun 21, 2008 | Cyberhome CH-DVD 300 DVD Player
Finalizing a dvd
Try this. In your SETUP options, ensure that AUTO FINALIZE and FINALIZE AT END OF TIMER are turned OFF.
Insert DVD. Press SETUP button. Be patient. Once DVD has loaded the DISK FINALIZE option will be available. You can then FINALIZE.
I found it much cheaper to get DVD-R from Radio Shack (about $5 for 25) for VHS movies that I know I want to keep. They do record up to 6 hours, even though the packaging is unclear on this point.
Dec 19, 2007 | Philips Magnavox DVD/VCR Dual Player
Won't load DVD for Initial IDM-7110
First check and see what is happening inside. Take something small and stick n the lock mech, which is the hold that a small part of you top to the player sticks in to tell the unit that it is closed. See if the lense light up and moves up and down and also see if it moves forward a bit and back to start position. If player does not do any of this then with fingers move lense down line abit to see if anything is obstruting path. You can move all the way down then place DVD in and try again
Aug 14, 2007 | Initial IDM-7110 Portable DVD Player
All of a sudden quit working
most portable dvd players arent meant to stay plugged in for long periods of time because they overcharge the batteries or cause damage to the players power supply regardless of how expensive they are .
However you can get a dvd player unit that is mounted in an overhead console (from a car stereo outlet that will last go to this site to see examples: www.mobilevideo4less.com/suv-systems.html - 40k
Mar 17, 2007 | kawasaki PVS-10921 Portable DVD Player
Daewoo DVG-9200N DVD Player Logo
236 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
