Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Remote won't work outside of garage it works up close
I replaced batteries, but it won't work at any distance.
  • 1 more comment
  • Anonymous Jan 15, 2009
    Same problem here and can't seem to figure it out. Please Help
  • Anonymous Feb 01, 2009
    Remote won't work beyond 10 feet outside of garage, it works up close. Is there any way to extend the range of the remotes or the receiver?
  • Anonymous Feb 03, 2009
    I also have same problem.
    Champion:
  • 244 Answers
Doesnt work at all or only close. if not at all, recode remote. if short distance, try reaiming antenna wire.
Posted on Jan 15, 2009
The klik3 works inside the garage but not outside the garage
make sure antenna wire is hanging loose and that the remote batteries are new
Aug 18, 2015 | Building Materials
How do I increase the range for the remote. Used to be ok but now only works through the garage window. Have tried replacing the batteries
There could be several causes for your issues.
If you have a FIOS box in the garage make sure that it is closed and sealed.
Make sure that there is on coax cable close to the garage door opener motor in the attic.
Could be a neighbor installed something that is causing you to loose distance.
Feb 16, 2015 | Building Materials
Garage door opener remote does'nt work when the garage door is shut
Probably you have a weak battery in your remote transmitter. When the garage door is closed it requires a stronger signal. Open the remote and replace the battery.
Oct 20, 2012 | Home Security
Remote does not work unless I am in the garage. Outside the door it will not work.
hello emar... check to be sure that the little wire antenna is hanging down from the back of the garage door opener motor. Then check it. If it still won't work from outside, install new batteries.
If that doesn't do it, remove the new batteries and use the eraser end of a common pencil to clean the battery contacts inside the remote. then reinstall the new batteries and try it again.
May 04, 2011 | liftmaster 83lm Billion Code 3-button...
My garage opener remote on my 2003 santa fe just stopped working. How can I fix it?
There is a battery in the remote.If the battery gets old the remote will stop working.Replace the battery and check.Also if your battery is new but still the problem is there then,try to open the garage door by keeping less distance between remote as well as the garage door.Also there is a sensor in the garage door.If that sensor is not functioning then this can be one issue.In some cases the internal remote circuit gets short,in that case the remote needs replacement.But does the garage door sensor light shows any sign of getting connection from remote when you press the remote button.Open the door and try to close the door with remote and check.As per the problem,in most cases its weak battery related problem,and replacing the battery solves the problem.You can try all the possibilities and see which one helps.Thanks.Helpmech.
Nov 12, 2010 | 2003 Hyundai Santa Fe
Raynor garage opener-remote only works close up sometimes
check to seee if the little wire that hangs out of the operator is hanging out. This wire is the ant. if this is not the problem replace the 12volt battery you can buy them anywhere. make sure you didn't cut off the ant. wire (I have seen customers cut thios wire thinking its an extra and not needed or place the wire inside the box very little signal that way have to be very close)
Jun 05, 2009 | Building Materials
Liftmaster Remote garage door openers work intermittently.
check to see if your ant. is up inside of the cover it's a little black wire that hangs outside of the operator shiould be about 6 inch.
Jun 02, 2009 | liftmaster Chamberlain Garage Door Opener...
Receiver
COULD BE A WEAK REMOTE BATTERY A BAD REMOTE OR A BAD RECEIVER.
YOU CAN BUY AN EXTERNAL UNIVERSAL RECEIVER. THAT CAN BE MOUNTED CLOSER TO THE DOOR AND IS CHEAPER THAN REPLACING THE CIRCUIT BOARD.
BUT REMEMBER, I HAVE SEEN A RV POWER INVERTER PARKED NEXT TO THE GARAGE STOP A NEW OPENER FROM WORKING AT A DISTANCE OF 5 FEET.
SO I ALWAYS SUGGEST TURNING OFF POWER TO EVERYTHING YOU CAN JUST AS A TEST.
HOPE THIS HELPS
Oct 31, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
462 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
