Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
Sony kp-51ws520 what bulb does it take
I have a sony kp-51ws520 rear projection tv what bulb does it take
  • Sony Master
  • 5,138 Answers
Tube numbers on tubes.Red Green Blue?
Posted on Dec 25, 2008
Tv blinks 5 times...picture wont come on...sony model kp-51ws520
internal power supply problem. needs to be checked by service tech shop. also try a different power outlet to see if the set does the same thing? if it does then follow the above.
Aug 22, 2011 | Sony KP-51WS520 51" Rear Projection...
I have sony wega sony wega tv kp 51ws520 no turn on just standby light blinking and i lost remot plz help me
Is the light blinking 9 times? If so thats a very common problem caused by failed diodes on the G board which will need to be replaced.
Jul 19, 2011 | Sony KP-51WS520 51" Rear Projection...
I'm looking for the correct part number for a Sony kp-51ws520 bulb (lamp) assembly .
The television you describe is a conventional projection color television, IT DOES NOT use a lamp. IT has three picture tubes that are not user serviceable. If the tv does not start it's probably an issue with the G-board.
Jul 11, 2011 | Sony KP-51WS520 51" Rear Projection...
No picture ,standby flash 10 times and tv turns off
10 times standby flashing indicates problem of High Voltage Protection and need to check following parts in Sony KP-51WS520 rear projection tv.
Q8014 or Q8013 have shorted replace along with R8051 on D Board
IC8005 is damaged (D Board)
Hope these info will help you. If you have no experience of electronics stuff repair then local tv repairman is an option to get help.
Thanks.
Nov 27, 2010 | Sony KP-51WS520 51" Rear Projection...
I have a Sony Kp-51ws520 5 blinks
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 22, 2010 | Sony KP-51WS520 51" Rear Projection...
Sony Projection TV KP-51WS520 won't come on. Blinks 5 times on front.
One of the Video amp ICs on one of the CRT drive boards has most likely failed.
Nov 27, 2009 | Sony KP-51WS520 51" Rear Projection...
KP-51WS520 wont turn on - standby & timer lights on constantlly
You need to check supply volts on main micro IC702 on main board of Sony KP-51WS520 TV.
If you have experience of big TV repair then I would recommend to get service manual of TV from any online store and check above said IC supply volts. TV must give error by blinking light in case any problem in drive circuits and if main micro fried, no error signal will be there.
Dec 05, 2008 | Sony KP-51WS520 51" Rear Projection...
I have a kp-51ws520 blinks 10 times
power fault. Can be repaired by local TV. Try www.mediarx.co.uk for TV repair
Oct 31, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-51WS520 Stand by flashes 5 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
This means that there is something wrong with the video.
When you get this error, several IC and components concerning the video signal must be tested and eventually replaced.
Mar 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
751 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
