Question about Polaroid PDM-0723 Portable DVD Player
Image dissapears but there is sound
When you play a disc you see the "blue polaroid" background then it goes really dark. you can hear the sound of the dvd however you can barely see anything. if you press the button that turns off the screena nd let go of the button. the screen will show again for 1 second.
  • 2 more comments
  • Anonymous Dec 24, 2007
    sound can be heard but picture is dark. screen lites up when you hit the depress button
  • Anonymous Mar 11, 2008
    same here
  • crownsbroyal Apr 10, 2008
    I have the same problem with my Panasonic portable dvd palyer
  • jtgluck Jun 23, 2008
    having the same problem with a Polaroid PDM-0723 Portable DVD player
My sister owns this unit, and like other users on this post, her screen quit working on her. She brought it over to me to see if I could fix it before she tossed it out. I first hooked the unit up to the TV with supplied A/V cables to see if the unit was outputting video. The unit supplied video to the TV fine, so I figured the problem was with the LCD screen or the connection from the unit to the LCD.
Like another user on this post, I noticed that the video would come on for a second or two when the small depress button was pressed, but then go blank again. (This button is at just below the LCD screen on the base unit – toward the middle of the base unit. You can see there is a small notch on the LCD screen that fits into this depress button when the unit is closed. This allows the unit to know when the LCD screen is closed.)
Here comes the fix that worked for my sister’s unit – I hope it works for yours also. . .
I decided to reset the screen to the factory settings through the setup menu. This is difficult to do when the screen is blank, so I figured I would have to go hook the unit up to the TV again in order to see the setup menu. Well, I had already put the AV cables away, and I felt too lazy to dig them out again. I decided to just navigate the setup menu by pressing the depress button on each menu, which the second or two of video would give me ample time to navigate the menu. Once I was in the first setup screen and depressed the depress button the screen came on like it had been doing when I was trying to view a movie, but low and behold it did not go off like it had been when trying to view video. Since I was in the setup screen I decided to reset the unit to factory default. I then exited the setup and played a movie. The screen did not go off. I have tried to get the screen to go blank again, but it stays on. It sounds like the problem is not with the LCD screen or its connection, but rather with the operating software of the unit. It is a piece of junk, but it is working for now. I hope this helps with your units also.
I also noticed some users posting a problem with an upside down screen. Hold down the mode button and the screen will cycle through different settings … one of which is upside down.
Posted on Nov 07, 2008
SOURCE:
POLAROID 40 Flatscreen
If there is a problem with the backlight inverter. the powersupply it goes into the security mode after start after a few seconds if there is something wrong .example image
Nov 20, 2015 | Polaroid Televison & Video
Polaroid sound problems
And you ale can't hear sound when played back on a computer or TV?
Sometimes people keep a finger on the microphone, but I think you should hear a muffled sound then.
Feb 02, 2014 | Polaroid iF045 Waterproof Digital Camera -...
No image - polaroid comes out and stays black
Probably defective when listed on eBay
Mar 01, 2018 | Photography
After i power my polaroid tv on the screen shows for about 3 seconds then goes black what causes that
Its a Lcd so if it stays on turn off all the lights (we want a dark room) and with flashlight look carefully at the screen to see if you see a faint image of a picture there or not.
Dec 06, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
I bought a Samsung AVR720 almost two years ago as well as a new Samsung blu-ray machine - to match our lovely Samsung series 6 TV (which our friend - who reviews all sorts of equipment - said was a really...
some of them require red , white, blue, green, an yellow audio jacks. make sure you have all the input plugs. or eles the tv will not use plugs it doesnt have.
Mar 05, 2017 | Samsung Televison & Video
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Sony kp-57ws500
Probable bad blue CRT and if blue goes bad guess what might
happen to the red and green.........T.
Nov 07, 2007 | Sony KP-46WT500 46" Rear Projection...
Dark Picture
...the answer is correct...the power inverter for the cathode backlight is a complete failure with these Polaroid models.  Polaroid should really step up and fix a known problem.  Mine was purchased as a gift and not opened until the worthless 3 month warranty expired.  Didn't work out of the box!!!! I will never purchase a Polaroid product again since they obviously don't care about the consumer and sell a product that they know was defective.
Nov 01, 2006 | Polaroid FDM0700A Under the Counter 7 LCD...
Polaroid PDM-0723 Portable DVD Player Logo
212 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
