Question about Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH
How can i put a connection password on my Encore IEEE 802.11g ?
I'd like to know how can i set a password on my Encore IEEE 802.11g router, so when you try to connect to my wireless connection it will ask for a password in order to establish the connection.
if somebody could help me..
thanks
Victor
  • jaumtapparo Dec 25, 2008
    what do I put on:
    Radius Server 1 --> IP ? 192.168.1.1?
    well, with WPA i cant connect, i reseted my modem.. tryed lots of things on my connection, but the only thing i found which works is WEP
    but when i try to set a WEP password, and i click on APLY, it doesnt do nothing, whats wrong?
    Scholar:
  • 100 Answers
Go to -
Start -> Run -> type CMD and press enter
when the box opens type
IPCONFIG/ALL and press enter
scroll down to the header Connection and look for Default Gateway
Copy this number down - make sure you write it down correctly
now type exit and press enter
open your web browser and type that number into the address bar and press enter
this will take you to your routers setup
enter your password if prompted. if you never set one the defsult Name=ADMIN and default password=ADMIN. if this doesn't work you may have to reset your router by holding in the reset button for thirty seconds and reconnecting to with the same i.p. address you used before.
go to Authentication Security
you can choose WEP or WPA i strongly urge you to use WPA. WEP is a very weak security type
let me know
Posted on Dec 25, 2008
  • Brian Ebeling Dec 25, 2008
    ok lets get you set up. do me a favor and go to --
    Start -> Control Panel -> System -> Hardware -> Device Manager
    Click on Network Adapters and tell me what it says in there.
    also what operating system are you using
    also please go back into the router through your browser again and somewhere on the page should be the model #, etc like EN???-???
    let me know
I get dr-655 configuration screen instead of ENHWI-2AN3 screen. Both my router and access point use 192.168.0.1 as the setup screen. how can i access the encore wizard instead of my router page?
Whenever you assign the same IP to the both the Modem and Router, this sort of this happens. In order to access the Modem, you have to either remove the router OR connect directly to the Modem (ENHWI-2AN3) through a patch of network cable connecting the cable at any of the LAN ports (yellow ones) and LAN card of your PC/Laptop.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 11, 2011 | Encore ENHWI2AN3 IEEE 80233u IEEE 80211bg...
Dear Sir / Madam, I would like to know the
The default settings are:
Username: admin
Password: admin
If that does not work then you may have to do a hard reset on your router. Note that this will wipe out any custom settings that may have been set on the router.
May 07, 2011 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
How to put password on my encore wifi router
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jan 05, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
HOW TO SET=UP A CODE SO THAT OTHERS CANNOT GET A SIGNAL FROM MY ROUTER
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
Oct 07, 2010 | Encore ENHWI2AN3 IEEE 80233u IEEE 80211bg...
Renew password
http://192.168.1.1
or
http://192.168.0.1
Click on wireless settings then WPA Security then not down code .It is your password to connect wi fi..
Then you can connect your wi fi network with that code.
Jun 22, 2010 | Encore ENHWI-N2 802.11n Wireless Router...
How can i put a password on my Encore ENHWI-N2 802.11n Wireless Router?
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Jan 06, 2010 | Encore ENHWI-N2 802.11n Wireless Router...
How do I redo password on my encore router cause
To change any setting on the router , you will need to access the router set up.
Do you have any computer connected to the router with the cable ?
If not then you will need to connect computer to the router
Open the router set up and change the wireless settings
Nov 30, 2009 | Encore 802.11G WIRELESS LAN ROUTER...
Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH Logo
760 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
