I believe that reverse is operated by a brake band. So it seems to be stuck. It is operated by a piston, and the seal could have swelled and caused too much friction. But you could loosen up the adjustor so that it is disengaged, in order to get forward gears again. Perhaps you can force the piston to retract as well, once you drop the pan again.
SOURCE: 1999 F350 crew cab 4x4 ford, gear shift lever
Ok ready to stand on your head under the dash?
It's doable... there is a flange connected to the gearshift lever under the steering column. If you remove the lower dash cover where the fuses are, you should be able to see it when you move the gear shift lever... look around on the floor of the truck to see if you dropped a star-headed bolt or two... these bolts worked loose on my superduty and made shifting very difficult..it was an easy fix... let me know how you do on it.
SOURCE: I have a Ford F250 Extended cab that started Running Rough
P0301 = Misfire cylinder #1P0303 = Misfire cylinder #2
P0171 = System too lean cylinder #1
Are you sure on the P1151 code? I am thinking this may be a P0151 which is O2 sensor related.
This looks like you have a fuel system related misfire. I would do a fuel injection cleaning service and then clear codes and see if the codes regenerate.
SOURCE: 1999 F250 only goes in reverse, no forward gears.
SOURCE: Looking for a diagram for a ford e4od transmission
Rebuilding an automatic transmission requires more than looking at a diagram. Check out faxonautoliterature. They have the original Ford service manual for your truck and it will have all the information that you will need to rebuild your trans properly. Hope this helps.
SOURCE: i replaced heater core on my 1995 ford pickup f250
how do I change the heater core on my 1992 ford ranger
it had a short and cot on fire, put out and drove off, need to replace
