Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water line is not working
Hi, I have a side by side Frigidaire the water line just automatily stop running. Can you guys please help?
    President:
  • 2,692 Answers
I would check the water filter first .If not that then:
Next disconnect the line and see if water flow is solid. If not then:
Lastly the water control selinoid is either clogged or defective.
Posted on Dec 25, 2008
Frigidaire Gallery Professional Series - FRS26ZSH My ice and water maker have stopped working. First the water stopped then about 5 days later the ice maker stopped.
you will need to replace the water inlet valve, this runs your water and ice,, before you replace it take your water line off and hold it in a pot, then have someone turn the water back on , this will let you know for sure you are getting water to the valve,, if no water comes out then you have a water line prob,, have that fixed then hook it back up and turn it on, then you will need to run the water for about 2 -3 minutes to purge the air out of the line,,, if you rplace the valve you will need to purge also
Jan 19, 2011 | Frigidaire FRS3R5EMB Side by Side...
I have a new Frigidaire whirlpool 3 month old . stop cooling and makes a lot of ice
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 28, 2010 | Frigidaire FRS26R4A Side by Side...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire water stopped working...ice maker.dispenser fine
You probably have an obstruction in filter compartment. you should remove filter and inspect o rings etc. or anything that could have clogged it up. The only other thing that could be the cause is a bad water valve. Side by sides have a double water valve. one for water ,one for ice maker. You can check this by having someone flip ice maker arm down so it calls for water and feel water valve as it runs and possibly hear it too. Hope this helps.
Jul 24, 2009 | Frigidaire FRS23KF7AB Side by Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water stopped running in the dispenser
i ihave a side by side samsung rsh1dbbp with ice and water dispenser but the water has stopped working i was wondering if you could tell me how to get the front panel off to check the switches
Mar 16, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Frigidaire side by side MRS22WNGD0 stopped dispensing ice and water
Even you find the problem you should need special equipment.Better call a technician.This link may help you:
http://www.appliance-parts-warehouse.com/frigidaire-parts/Frigidaire-Refrigerator-Parts/Frigidaire-Parts-MRS22WNGD0.cfm
Nov 18, 2007 | Refrigerators
Keeps defrosting or stoping all together.
Check that the AC outlet works where the unit plug. Its seems that you have a power loss problem, either on the unit or in the wall outlet.
Aug 04, 2007 | Frigidaire FRS26KF6E Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
98 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
