Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Sony kds-r50xbr1 all white colors on any tv programs is green.
Green screen problem. everything i watch is away green
  • Henry McKelvey
    Henry McKelvey May 11, 2010
    Hello j wright,
    What video inputs are you using? If you are using the RGB inputs make sure the cables are connected correctly. Please inform of the connections you are using. Once this is done tell me if the problem clears, if not there might be a video output problem.
    Thank you,
I had a similar problem, with green patches appearing on the corners of the image. Did you register your TV to Sony when you bought it? I did, and received an email regarding a class action. There is a known issue with the optic block in this TV, and I had mine replaced for free. The new block started to do the same, and they replaced that for free too (it was through Sears). The optic block is a $1000 part. Here is a link to the class action. I think you might be stuck, however, since I believe the deadline for sorting this problem out with the class action settlement has passed.
Here is a link to Sony:
http://esupport.sony.com/US/perl/news-item.pl?mdl=KDSR50XBR1&news_id=219
Hope you get it sorted out!
Posted on Jan 06, 2009
I have a Sony KDS-R50XBR1 after replacing the lamp the color on the screen is very green. Is there a reset code or a instalation code to get into adjust the green past the custom white balance? Any help...
No reset is necessary for this problem. You have a defect in the optical engine. The part can run as high as $800-900 and more with labor. It's best to try to get a refund on your lamp and call it quits on this set compared to the cost of a new one. Sorry
Bill W
integrityhomeworx.com
Mar 08, 2011 | Sony KDS-R50XBR1 50" HDTV
The color is off. Everything looks either green or yellow.
This is a light engine that is failing and a VERY common issue. Contact Sony because the warranty on these light engines was extended until June 30th of this year under bulletin E30020889. It is probably worth it as a consumer to call and see what they will do for you since this was really a design flaw. Please take a few moments to rate my answer. Thanks...
Nov 20, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS-R50XBR1 50 in. HDTV picture cycles on and off
It is clear symptoms of weak lamp in TV, replace lamp to correct that problem.
Lamp replacement is easy and written in user manual of TV.
Please buy Sony original lamp for TV safety.
Thanks.
Nov 17, 2009 | Sony KDS-R50XBR1 50" HDTV
We are noticing a green tint on our Sony KDS-R50XBR1
You have what is referred to as the "Green Blob". Sony messed up bad with the Optical Light Engine. They didnt realize until months after releasing the model you and I have they had a huge problem. So they figured not all Engines were bad. So technically, they havent recalled. I went through several months of talking with Sony and my warranty. You will need to call a tech and have them check to make sure. My tech knew what it was by me telling him over the phone. Hes worked on a more than he cared to say. Sony will play games. They will want a considerable deposit put down before sending the new Engine. And if thats not the problem...they keep your money!!!AAAAHHHHH!!!!I feel for you. I pray you have better service than me. Its been a year since. so maybe they are better. God Bless!!
Aug 15, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony KDS R50XBR1 TV, LIME GREEN PIC
if all sources and hdmi cable are good--you need the hdmi input board--dont know sonys letter designation
Jul 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kds-r50xbr1 turns itself off and then green light blinks 52 times
Just replace its Lamp and procedure is written in user manual of KDS-R50XBR1
F93087600 XL-5100 LAMP BLOCK
Lamp is available in Sony Accessories and price is $250
Always buy Sony original lamp for good picture in TV and avoid aftermarket / cheap lamps that can cause damage of TV circuits.
Click Sony Support to download Instruction Manual copy, if you want it.
Apr 22, 2009 | Sony Video Cameras
My tv is screen is green
Sounds like your optical block neeeds replaced, my kds-r50xbr1 just started getting the yellow-green haze who knew $3000 t.v's would only last 2 years urghh check out this link to sony and call the (866) 850-8674
Apr 15, 2009 | Sony KDS-R50XBR1 50" HDTV
KDS-R50XBR1 50 in. HDTV Television: I can't get rid of the GREEN
Its another instance of the optical block (light engine) failure these TVs are known for. Heat from the lamp has damaged the LCD panels in the light engine. Sony has been directed by the attorney general's office in New York to warranty these TVs going back 4 model years. Call Sony at: 1-800-222-SONY for assistance.
michtech
Jan 24, 2009 | Sony KDS-R50XBR1 50" HDTV
WEGA only show yellow
Hello watts74:
When you turn your tv on, you still get an image of whatever channel you are on, but the background on the entire screen is green/yellow, correct? If so, the problem is the optical block. Read what I posted below on another thread and you should be on your way to getting your situation resolved.
Here is the link to the other thread I mentioned: http://www.fixya.com/support/t157434-green
All the best...
By nonexpert_s.gif KDS-R50XBR1
Rank: Apprentice
Rating: 0%, 0 votes
If your SONY KDS-R50XBR1 or KDS-R60XBR1 color screen suddenly turns green, the optical block (aka light engine) is the culprit. Don't fret because as "Leadtech" has already posted back on Jul 04, 2007, SONY is aware of this problem and has extended the warranty to replace this very part. Additionally, and aside from the class action lawsuit currently pending in district court, parts and labor for in-house service IS included.
SONY states the warranty as follows:
"As part of the Sony commitment to quality, Sony is announcing that it is extending the limited warranty (parts and labor), in the United States, on the optical block of KDS-R50XBR1 and KDS-R60XBR1 model SXRD televisions until October 31, 2008, regardless of purchase date."
So all you have to do is:
1) Contact SONY Customer Service at (800) 222-7669 or (888) 772-7669 - Hours: Mon-Fri 9:00AM-10:00PM / Sat-Sun 10:30AM-7:15PM EST
2) Provide them with your model (as above) and your television's serial number
3) Tell them your screen color is nothing but green
4) They will provide you with a case number
5) They will ask you for your zip code and provide you with one or more SONY authorized service dealers, and their contact information.
6) You contact the dealer of your choice and schedule an in-house service. Explain to them that your screen is green and you are aware that many, same tv-model owners that have had this same problem, and that the optical block is the problem.
7) The SONY authorized dealer you speak with will schedule and appointment with you, and will provide in-house service.
Regarding the service, it will take about an hour to complete. Not that it is complicated for the technician, but where the optical block is located is that is time-consuming. It sits just "behind" the bottom of the tv screen and in order to get to it, the technician will have to:
1) Remove the bottom back gray cover
2) Remove the replaceable projection lamp located on the left side of the tv (looking from the back)
3) Remove lots of phillips screws
4) Disconnect many plugs
5) Remove 3 chassis closest to the back of the tv before getting to the optical block chassis, which is located up front, just behind the tv screen
Once the optical block is replaced, you will be amazed on correct color results.
Hope this helps...
Oct 15, 2007 | Sony KDS-R50XBR1 50" HDTV
Green
2) Provide them with your model (as above) and serial number
Hope this helps...
Jul 02, 2007 | Sony KDS-R50XBR1 50" HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
