Question about Mtd 22" White Outdoor Self Propelled High Wheel Mower
Snow blower self propel works intermitantly, motor and auger run
Its an MTD two stage blower model 3BA, auger and motor run fine but self propel drive fails or run intermitantly making the machine useless
I did inspect the belts, both are fine,
The auger sometimes does not move until I move manually first
SOURCE: I have a self propelled MTD Model #12AV55DQ513
I have a MTD PRO Model#12AV55DQ513 as well. The bell hub under the lawn mower has now cracked and chipped for the 2nd time. Taking it to a local MTD rep near here is difficult cause it's too far to go. Anyone know of other reps close to Port Moody, BC, Canada? Anywhere in the Vancouver, BC area?
Posted on Oct 31, 2009
rwvanlue
  • 486 Answers
SOURCE: MTD front wheel drive self-propelled 21
Yes it can be fixed. Try some basics first.
1) Check under belt drive cover for excess debris
2) Belt and Idler pulley condition
3) Control cable operation
a) rusted, frozen, broken, disconnected
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Dec 04, 2009
  • 144 Answers
SOURCE: My MTD 10hp auger will
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
Posted on Jan 09, 2011
SOURCE: how to adjust a 9460897 mtd snow blower auger
On the handle end (usually) of the cable is a curved metal connector. Attached to the connector is a threaded rod with a nut. Attach a pair of pliers to the threaded cylinder that the threaded rod goes into. Loosen the nut. Turn the threaded cylinder into the threaded rod to tighten or out to loosen. When you have the correct adjustment, tighten the nut back down onto the cylinder. To be correctly adjusted, pull the cover off the auger belt and push down on the handle. The spring attached to the cable at the pulley end should stretch out when the handle is fully depressed. Spring tension keeps the belt tight. iaff801.jpg
Posted on Feb 15, 2011
Knucklebstr
  • 222 Answers
SOURCE: how do u change the
Please follow this link to the MTD website which will give you step by step instructions. I hope this works for your model as well. Best of luck to you and "Happy Motoring". James
http://tinyurl.com/3vpwdts
Posted on Jun 28, 2011
Snow blower runs and auger/ blade rotates but the wheels Anne not rotating. 2- stage Aries 5520. Not sure if the thrower piece is rotating. Any answers for getting wheel moving/ working
Most self propelled units have 2 belts. One for the auger, and one to power the wheels. Check the belts, and then check the drive assembly under the motor to see if it is engaging.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Dec 03, 2016 | Garden
I have an MTD single-stage snow blower that I replace the other the cable and the belt and under a load it's still not throwing snow
There should be 2 holes on the handle that engages the auger belt, use the top hole as it will increase the belt tension.
Check the condition of the rubber auger's rubber paddles as they are subject to wear and should be replaced if any signs of excessive
wear is present.
Jan 31, 2016 | Craftsman 21" 179cc* Single Stage...
Was wondering if anyone would know the age of this snowblower and hp output, its for sale and before I buy I would like more info about it. It says Snow Champ 5/24 power propelled
Looks like the UP605/8461 was made for Aircap by MTD for just 1 year (1989)... the equivalent MTD model number was: 319-550-002
Here are some links to sources for available parts along with obsolete replacement/aftermarket recommendations:
MTD UP605 8461 319 550 002 Snow Champ Self Propelled Snow Thrower 1989...
MTD 319 550 002 UP605 8461 1989 Parts Parts Diagrams
The parts that go bad the most often are the wear skids on the outside of the auger housing, and the shave plate along the bottom edge of the auger housing.
Carburetors tend to gel up from the 15% ethanol the farm lobby got congress to put in all our gasoline, but that's not really 'going bad' - often you can actually clean the 'varnish' out of the orifices and passages with aerosol carb cleaner... shops would have a heated (about 105F) ultrasonic parts cleaner, but it's usually cheaper for DIY'ers to buy a new carb.
Mar 08, 2015 | Garden
I have a MTD snowblower yard machine.how to adjust
There should be metal shoes on the side of the snowblower. They have adjustment bolts that allow the auger housing to move up and down. loosen them and adjust to how close you want it to the ground. It also depends on the model. This process only applies to large self propelled models which are a two stage snowthrower. if its a small single stage there is usually no adjustment.
Oct 19, 2014 | Garden
Mtd yardmachine snow blower 305 cc auger wont turn
This is a fairly frequent problem that is easily fixed. What happened was the snowblower's auger was either overloaded or got jammed (ice, debris - something other than snow). Rather than twist, damage or break the auger itself, an inexpensive part called a "shear pin" is designed to fail. A shear pin employed between the auger sleeve and drive shaft that is inside the sleeve. You may have broken one if one side of the auger spins) or both (if both sides of the auger spins). Purchase several replacements for your particular machine to have on hand. Do NOT replace s shear pin (or shear bolt) with a regular bolt under any circumstances! Check the video linked below on how to replace the shear pins. Good luck!
Feb 09, 2014 | Yard Machines 28" Two-Stage Snowthrower
Yardman snowblower won't self-propel
Do not start to do this but put the blower in gear like you would run to drive its self and try to turn the wheels by hand and if they turn easily then you may have a shear pin that is broken or missing in the drive pulley.
Just a thought.
Dec 12, 2013 | Yardman Yard-Man 31AH65LG701 357cc Gas...
I have a snow king 5hp snow blower. while clearing snow, the snow only oozes out the shoot.
IT SOUNDS LIKE YOU HAVE A TWO STAGE SNOWBLOWER WITH ONLY ONE STAGE WORKING. I BET THAT YOUR PROBLEM IS THE AUGER IS TURNING BUT THE IMPELLER BLADE THAT IS BEHIND THE AUGER HAS PROBABLY JAMMED UP WITH SOMETHING AND IS SPINNING ON THE SHAFT. YOU WILL HAVE TO REACH BACK AND GRAB IT AND TRY TO TURN IT ON THE SHAFT BY HAND.MAKE SURE THE BLOWER IF OFF!!!! . IF YOU CAN TURN IT BY HAND EASILY IT HAS EITHER BROKE A SHEAR PIN OR BOLT OR SOME TIMES THEY WILL TACK WELD THEM TO THEM TO THE SHAFT. GOOD LUCK
Jan 17, 2011 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Mtd 22" White Outdoor Self Propelled High Wheel Mower Logo
400 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
lnbn1975
Morne Olivier
Are you a Mtd Garden Expert? Answer questions, earn points and help others
