Question about Samsung HLM5065W 50" Rear Projection HDTV-Ready Television
Flashing My Samsung HLM5065W is just over four years old. I just replaced the lamp for the second time and still have a terrific picture. But now after 30-90 minutes of the set being on, there is a "flashing" effect of white light, especially in the bright areas of a scene. The fan is running, there is no excessive dust buildup on the cooling vents. Any ideas? suggestions? Thanks in advance for any help.
  • gbreedingj Jan 12, 2008
    after about 20 minutes, the light colors start flashing, not the dark colors, i have changed the lamp last year, color wheel last year any ideas its getting worse
  • Anonymous Feb 03, 2009
    I have a similar problem, things in the picture flashes white, as if I am taking a picture of it and the flash from the camera is reflecting off the people in the picture. Can anyone help? I am not sure whether to service it, I dont want to pay someone $100 to tell me its trash.
Just spent $126.00 to find out that it is the DMD Mirror Board and another board total cost to repair is over $1,000 including labor.
Posted on Jan 30, 2008
  • Kevin Wertz
    Kevin Wertz Mar 19, 2012
    gbreedingj: did you end up making this repair or did you just buy a new tv? I am actually leaning toward the color wheel as the problem here on my HLN-567W. Apparently sometimes you can start having this problem without any noise coming from the color wheel.
I am currently having the same problem. It started they way you are discribing, but now the TV will do that after the TV has been on for 20min and then will shut off within 30min. Then all the lights up front flash. I have replaced the bulb and that was not the problem. I also NEED HELP! Occasionally the picture on my TV will be inverted and sort of "dance" back and forth on the screen.
Posted on Oct 21, 2007
When I power the TV on there is no picture, the lamp light is flashing, and there is a squeaking noise coming from there rear of the TV. It kind of sounds like a wheel turning and rubbing against...
Hello.
First you have to replace the lamp.
You can real owner's manual for info of how to do it. Lamps are available on-line.
It has to be done every 2.5 years of average use. Noise could be produced by ballast trying to start faulty old lamp.
If you still have problem after lamp replacement - color wheel could be another noisy reason. In this case you need to get professional assistance.
regards.
Russ.
Dec 01, 2010 | Samsung HL-R4667W Rear Projection...
Sony Wega Television - Sound and no picture
If this is a LCD projection then its time for a new lamp. Have your lamp placed.
Please leave comment:
thanks
Oct 06, 2009 | Sony KP-FX532M91 TV
Tv will turn on but no picture...stand by, timer and lamp lights flashing
Bad Lamp Part # BP96-00224c- You can find good Deals on Lamp at E-bay i just got one for 85.00 I have the same TV in my bedroom.
Sep 18, 2009 | Samsung HLM5065W 50" Rear Projection...
Screen is black tv wont come on, power on lights flash
Replace Lamp ,Go to E-Bay lamp number is BP96-00224c, I just got one for $85.00.
Aug 20, 2009 | Samsung HLM5065W 50" Rear Projection...
My samsung dlp has no picture or sound. Model hls5066wx, power comes on lamp light flashes for 15sec and then the standby lamp comes on then it goes back to the lamp light flashing. It repeats this a few...
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 12, 2009 | Samsung HL-67A510 67" DLP HDTV
Samsung HLM5065W DLP shuts itself off for no apparent reason
I just had the same exact problem. New bulb and all. Tech. said it was the Light Engine assemble was going bad. Here is some photos of the Light Engine.
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
Nov 22, 2008 | Samsung HLM5065W 50" Rear Projection...
50? Samsung DLP TV Model #HLR-5067W
Did you use an original replacement lamp or an aftermarket replacement? From the price you give, it sounds like an aftermarket lamp, which are notoriously buggy and the problem may be with the lamp. If not, the lamp driver is your next likely culprit. It is also called a lamp power supply or lamp ballast.
Oct 19, 2008 | Samsung DLP HL-P5663W 56" TV
Troubleshooting Problems
Just click below for the site links inside;
http://www.fixya.com/support/t935135-fan_failure
Hope it may help you;
Regards,
VOTIT
Sep 23, 2008 | Samsung HLM5065W 50" Rear Projection...
SANSUNG HD TV
I have the HLM-5065W DLP TV. Replaced lamp 1 year ago. It attemps to start 3 times before shutting down. then all light are flashing. I hear an electrical sparking and I see the bulb flicker but that it. Did the bulb go out again? IF so why so soon. If not what is the problem??
Apr 17, 2008 | Samsung HLM5065W 50" Rear Projection...
Samsung HLM5065W 50" Rear Projection HDTV-Ready Television Logo
213 people viewed this question
Jerry Greenberg
Jerry Greenberg
