Question about Logitech QuickCam Communicate STX Personal Web Camera
E3560 I installed and uninstalled the software, and still am not able to get the microphone to recognize any sounds... Any ideas?
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Posted on Jan 31, 2009
Sound capturing problem
Webcam doesn't record sound,try a microphone,and make sure that sound recording software is running when you record sound
Aug 27, 2012 | Gateway Computers & Internet
ATR3350 Microphone: Battery in. Plugged into laptop. Recorded video. ATR3350 Mic is ignored. Audio is still recorded from my Logitech Webcam software. How does this thing work?
You need to tell your computer which microphone / sound source to use.
In he absence of other instructions it is defaulting to the built in microphone.
Normally your sound-card software should detect a new device plugged in and ask you to confirm it. However if it is not doing so you may need to change the audio settings.
How to correct this will vary slightly depending on which operating system you are using.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls). If your webcam/ microphone is built in to the laptop there should also be a volume control called 'Internal MIC' - disable it by placing a check-mark in the mute box.
NOTE if microphone (or internal MIC) is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it but it is possible you may also need to turn off the microphone in the software for your web-cam.
Feb 09, 2011 | Audio Technica ATR3350 Microphone
My Netgear WG111v2 adapter seems to have given up. Tried re-installing software but the PC does not seem to recognize the existence of the hardware. Any ideas or do you think it's Donald D'd
Sounds like, may be the first time you install the software driver you might have selected the option "Donot prompt me to install the software Again"
Open Device manager and find is there is any exclamation mark next to the Wireless adapter, if so uninstall the driver and search for new hardware, it should work.
Good Luck.
Feb 15, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
WEB CAM NOT RECOGNICED
Step 1: The "Tools" menu of Windows Live Messenger
1. Recover Windows Live Messenger in our software if you do not have it yet.
2. Start the installation of the software.
3. Once this is done, go to the Tools menu software.
In this menu, two links are important in order to properly configure your camera:"Setting audio and video" and "Parameters of the webcam."This is the first that we will discuss first and foremost, the second used primarily to adjust the parameters of the image in the secondary stage but we are dealing with. Launch therefore setup wizard and click on "Next".
Step 2: The setting of loudspeakers
1. Select your hardware in the menu.
2. Check the box if you use a helmet.
3. Test finally your sound output in order to adjust the volume.
It is possible that you find in the menu several choices. That means you have several elements in your computer capable of transmitting sound, a dedicated card and your motherboard, for example. In this case, make sure to select well the correct input, what you quickly verify the test by loudspeakers.
Step 3: At the turn of the microphone
1. Select your sound source.
2. Start talking to your microphone.
3. Observe the cursor, if it moves, your microphone is working.
Two remarks on the stage configuration. On the one hand, if your camera has no microphone, you must go through a device that you must annex plug into the pink on your sound card. On the other hand, if your mouse does not work, you may have selected the wrong input device sound. Take particular care in this setting and not leave this page only when the cursor s'agitera,
indicating that your voice is recognized by the software.
Step 4: Turning finally to the image
1. Specify this time the source of the video.
2. Observe the window of return: if your setup is satisfactory, your image should appear.
3. Adjust the frame rendering through the "Option" button.
Aug 03, 2009 | Microsoft LifeCam VX-3000 Web Camera
Installed Quickcam Deluxe and it shuts off my sound.
Dec 17, 2008 | Logitech QuickCam for Notebooks Deluxe
I have a mac G3, and have os x ver. 10.3.9 I just bought the logitech E3560 webcam, how can I install it? It's not loading anything from the installation disk!
It sounds like your camera is not compatible with Mac OS. The disc may only have the software for Windows. Go to Logitech web site and see if you can find the software for Mac.
Dec 02, 2008 | Computers & Internet
Microphone not being recognized
is it in correct hole the one with a picture of a mic on it
Jul 30, 2008 | Philips Dynamic Edge 4.1 PSC604 Sound Card
Logitech quickcam software audio difficulty
May 26, 2008 | Logitech QuickCam Pro 5000 Webcam
Cyber Acoustics PC Microphone Not Working Anymore
Well to find out if your computer even recognizes it, you need to right click the white speaker on the bottom right of your computer. Select audio devices. More than likely it will tell you it isn't connected.
I uninstalled the sound completely from my computer. Then i restarted the computer. This will reinstall the drivers for your sound and the one you need for your mic. I have vista but this should still work for XP.
-right click on computer (should be on ur desktop or under start menu)
-select manage
-device manager
-click on the plus next to sound, video and game controllers
-right click on the audio (high definition audio device)
-select uninstall
- restart your computer.
This will do the trick.
your computer should recognize the mic.
Oct 27, 2007 | Cyber Acoustics CV-1064 Microphone
Logitech QuickCam Communicate STX Personal Web Camera Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
