Question about HTC G1
My g1 has a multicoloured, frozen screen.
I switched my G1 on and it came up with four colours on the screen and i can't press any buttons, or use the touch screen.
    Problem Solver:
  • 3 Answers
Remove battery. It happened to me twice now and all I could do was remove the battery, the phone responded to that LOL
Posted on Dec 27, 2008
Ok so i got a G1, and the problem is it wont turn on. even when i charge it, it wont turn on. The farthest it goes it to opening where it says G1 and then it turns off after that. Whats wrong with it, do i...
Try hard resetting it once. But make sure you have enough charge. But this will erase everything.
To perform a Hard Reset
  1. Turn the phone off. If it is frozen, take the battery out and put it back in.
  2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
  3. Press Alt+L.
  4. Press Alt+W for a factory reset.
  5. Press the Home and Back keys again for about 25 seconds.
http://www.resetcellphone.com/solution/HTC/g1
Jul 27, 2011 | HTC G1
My G1 Android will come on and show T-Mobile G1 then Android will come up but then the screen is blank? What can I do?
the best solution is to hard reset, follow the instructions bellow
1. Turn the G1 off. If it's frozen on, take the battery out and put it back in the unit.
Now to wipe the device clean:
3. Press Alt+L.
The device should then reset again and the hard reset is complete.
Mar 10, 2011 | HTC G1
How do i get free unlock code for g1 google phone
Dear,
  • 1. Side out the Keyboard / Open Left Hand side Notch to unlock Battery Panel.
  • 2. Insert TMobile SIM Card and Battery.
  • 3. Press MENU Button Constantly and Switch the Phone using Red Talk End / Power Button but do not Release the Menu Key.
  • 4. This will put on the Phone in Safe Mode.
  • 5. Press to Emergency Dial Button, Windows dial *#06# and this will show IMEI Number: note it down and also Recheck IMEI with Box.
  • 6. Give IMEI to Unlock Code Provider www.unlock-tmobileg1.com and get the Unlock Code.
  • 7. Now Return to main Screen and Press MENU Button this Will popup APN Button, Just Press it.
  • 8. Go to APN Setting. There will be so many APN already Preset. Again Press MENU Button this will show NEW APN Popup Button again Press.
  • 9. Remember to put Right MCC (Mobile Country Code), and MNC Mobile Network Code, G1 Matches SIM card Data of MCC / MNC with these Setting and then try to use that. Settings.
    All World MCC / MNC codes is available here:
    http://en.wikipedia.org/wiki/Mobile_network_code
  • 10. Now Switch off the Phone and Wait for Unlock codes.
  • 11. Insert the Non T-Mobile SIM Card which you intend to use it with G1 and switch G1 on. (Your SIM must have
    Data plan / GPRS Activated so G1 will able to contact google.com for Activation)
  • 12. HTC G1 will ask for Unlock Codes. Type unlock code carefully, typing wrong code thrice may make Phone Hardware Locked.
  • 13. Once Unlocked your GPRS / EDGE / 3G Data Service will be active as per APN Setting we did before.
  • 14. Type Google User name / Password in Signing Window and this will Activate the Unlock G1 Device on your SIM Card.
  • 15. Make other remaining Data Setting like MMS / Home Page / Port to Active other Data Service
Thanks
Sep 14, 2010 | HTC Google G1/Dream Cell Phone Black...
G1 got little wet but it dried out and screen shows all but now triangle and cant get touchscreen to work....what do i do?
If it got wet it might still be wet from the inside and that is why your touch screen wont work, You would need to open it and clean it from inside. Or it could have a bad digitizer and that is a second reason why the touch screen wouldnt work. You can try doing a hard reset if you says it just shows a triangle on the screen.
Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit.Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle
Press Alt+L. Press Alt+W for a factory reset.
Jun 15, 2010 | HTC G1
G1 is frozen after new system update its been 30mins and i already took the battery out to restart it
This was copied from a site on the web. I personally have used the instructions below and it worked for restoring my G1. Once it is restored, you may want to try to run the update again.
1. Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit.
3. Press Alt+L.
The phone should reset again and the hard reset is complete.
Mar 09, 2010 | HTC G1
How do you hard reset g1?
If your T-Mobile G1 Google smartphone is not responding or is frozen, you may have to opt for a hard reset. Here’s how:
3. Press Alt+L.
Sep 24, 2009 | HTC G1
Blue light on top of g1
I solved this problem by booting into SAFE MODE on the G1:
Press Menu Button and Switch on the G1 Phone using Power button. (Do not release menu Key).
That Got it to turn on. but upon power down it did the same thing with blue light. So I always start in SAFE MODE. I will start uninstalling programs until i find out which one is causing problem.
Sep 11, 2009 | HTC G1
G1 keeps frezing up. tryed to reset but it still frezing up.
do a hard reset.
3. Press Alt+L.
Jan 21, 2009 | HTC G1 Smartphone
Froozen
do a hard reset.
3. Press Alt+L.
Oct 24, 2008 | HTC G1 Smartphone
HTC G1 Logo
348 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
