Question about Microsoft Windows XP Media Center Edition 2005 for PC
Windows media center file issue
When I record TV from a cable premium channel, I can only view it on through the media center program on my computer. I would like to be able to view these files on a different computer with windows media player. Recording on non premium channels works fine.
  • 38 Answers
Some premium channels have DRM locks so that they aren't able to be copied or played on other players, which is most likely what's happening here.
Posted on Jan 31, 2009
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Windows media player won't play any audio selections , says can't find files
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display. The Xbox 360 gaming console is an example of an extender.
Click on "Allow a program or feature through Windows Firewall." Click to check "Media Center Extenders." Click on "Apply."
Click on "General" and select "Windows Media Center Setup." Click on "Set Up Your Speakers." Follow the on-screen prompts to reconfigure your speakers.
and you should run the chkdsk utilty
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way i have found to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive.
hope this helps
Oct 23, 2012 | Toshiba Satellite A60-692...
How to use in built TV tuner in lenovo y560 laptop
In windows 7 - Windows Media Center will use it (NOT media PLAYER, media CENTER)
media center is actually wicked cool for watching TV because if you have cable, no more waiting for the listings channel...it pulls up to 2 weeks of listings from your provider, so you can schedule shows to be recorded, record series etc...very cool!
Mar 03, 2011 | IBM Computers & Internet
How to record the live tv show programs
Hi. Check if you have windows Media Center. If you have, then you might need to configure it to recieve local or cable channels. Just don't forget to connect an antennae or cable and provided that you have a TV Tuner Card. ^_^
May 12, 2010 | Dell Computers & Internet
Media Centre - uninstall?
Here is the main features of Media Center.
Media Center.M View your photos in a cinematic slide show, browse your music collection by cover art, easily play DVDs, watch and record TV shows, download movies, and project your home videos.
Windows Media Center offers built-in support for archiving TV shows directly to video DVDs and a platform for content owners to deliver new online entertainment services and experiences.U For U.S.-based customers, Windows Media Center offers support for digital cable service, by means of a digital cable tuner.
Frankly speaking I'm using Windows 7 but never had the need of using media center.It cost huge on system resource when running,Even when you watch video it will load other features too when the Media Center start. you can uninstalled it without any worry.
here is the page link on how to disable and uninstalled Media center.why I am giving you this link is, it can't be uninstalled using windows same old add/remove program tools in control panel.
http://www.mydigitallife.info/2008/02/23/how-to-disable-uninstall-and-remove-windows-media-center-in-vista/
Have a very Happy New Year.
Dec 31, 2009 | Sony VAIO VGN-FE550G Notebook
I have a Kworld TV878 TV card. I need a program for watching TV channels. Could you please send me a software for windows 7 to my e-mail address.
There actually is software built into the Home Premium, Business and Ultimate versions of Windows that can do that. It's called Windows Media Center. This can also be purchased and downloaded for other versions of Windows 7.
I hope this answers your question,
Yannick.
Dec 07, 2009 | KWorld TV878 TV Input
What is a cabel card
A cablecard is the size of a credit card use to view or record digital cable channels on a digital recorder,personal computers and tv s without the use of outside equipment like (stb) set top box provided by your cable company, below is a picture of one hope this helps.
Aug 12, 2009 | Zenith Z37LZ5D 37 in. LCD TV
Windows XP Media Center stopped working
Seems like a virus or spyware on the computer:
Uninstall any existing security program like norton or mcafee by using their removal tools from http://pcsafety.us/
from the same site download and run AVG antivirus free, Super Antispyware - update and perform a complete scan on all the drives.
If these dont work you need to run combofix but that may crash your pc so keep it as a last resort.
You can take it to geek squad but they wond do all this they will simply format your harddrive and you lose all your data.
Hope this helped!
Rate this fix if it worked'
Keshey
Jan 22, 2009 | Microsoft Windows XP Media Center Edition...
PARENTAL CONTROLS WINDOWS VISTA MEDIA CENTER
Hi, I recently wrote a program to easily crack ANY Windows Media Center Parental Control Access Code. On a fast enough computer this can be done in under a minute. The program can be downloaded at http://www.mediafire.com/file/uzfzwmmuinf/MCPC-Bruteforcer.exe -- Enjoy!
May 09, 2008 | Computers & Internet
Dual toner card
You will have to install each tv turner software not different folder in the program files folder.
During the installation of the drivers and software you will be prompted with the directory where the software will be installed, on this page you should select say for eg:
for the first tv turner card C:\program files\ hp tv turner
for the second tv turner card say c:\program files \hp tv turner 2
this should be done for every directory mentioned during the installation.
other wise both the card will try to use the same driver and software files, there will be a clash, thus one one tv turner card will be viewed.
Jan 09, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows XP Media Center Edition 2005 for PC Logo
88 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
