make sure the power is off
press ex bass to check which programs are set.
to cancel
press srs 3d till all timer lights are off
it cycles prog 1
prog 2
prog 1,2
timers off
I have a Kenwood hi-fi system XD Series. the three disc draw won't open or play discs. The table shudders when on...can anyone please find a repairer in the adelaide district.
I am able to help with part of this. Your glow plug timer should be close to the glow plugs and it is behind the motor on a Ford. You should be able to find it on your Chevy by following the wires from the glowplugs to a plastic box. Even if the ignition relay is stuck on, the glowplug timer should cycle and cutoff.
You should verify with a voltmeter if your glowplugs are still getting juice with the ignition ON longterm AFTER THEY CYCLE or if it is just the dash indicator light thats on. Some glowplugs run below 12volts so don't worry about a low reading.
Check with Autozone or Oreillys for your parts and location. You could have a bad ignition switch, ignition relay, and or timer. The diesel system is wired differently than a gas sytem because diesels use compression for igniton and is switched off differently than a gas motor. You could be getting a glowplug light because it is grounding through the light.
