Question about Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA Receiver Car Video Player
Hooking up TV tuner
The antena lights are on, Its like im getting no signal to monitor. all the cables are pluged in . Thanks Cory Chapin
0 characters
1 Points
Find a wire harness diagram to hook up a valor its 700w
he pink wire is for a power antena or amplifier signal
The red wire with Black stripe is your Key On power to the radio
Read more:
The pink wire is for a power antena or amplifier signal
Sep 06, 2014 | Valor ITS-700W 7-Inch In Dash DVD Monitor...
Wich video format supported
Released 2 years ago Included Units Stand-Alone Monitor, Amplifier
Supported Audio Formats MP3, WMA
TV Tuner Without TV Tuner
Radio Tuner AM, FM, Satellite, XM Ready
Aspect Ratio 16:9
Input Connectors AV x 1
Monitor Size 7 inch
Output Connectors AV x 1
Power Per Channel 50 Watts x
Supported Media Types DVD Video, DVD+R, DVD+RW, CD-R, CD-RW
Supported Video Formats DVD, DivX
Dolby Digital / AC3
I found all of this at
Good luck.
Hope this helps!
Jan 21, 2011 | Clarion MAX685BT Car DVD Player
My car tv does not turn on and all the fuses are good
Since you are sure about the fuse why not see if the monitor unit gets the power or if there is a line break. If the power does come to the main board in the set, check if the regulator in the front end power is supplying the supply to the main IC.
Check the signal from the player to the monitor, if possible test on your TV with an extended cable.
However if the power and the signals are normal, then it is possible that the monitor IC has failed.decide with the cost and availability if reasonable.
hope this helps.
Aug 19, 2010 | Concept P1020 Car DVD Player
Pioneer AVH P6500DVD Tuner Failed
sounds like the antena plug on the back of the unit came out pull out an check
Jul 15, 2010 | Pioneer AVH-P6500DVD Car DVD Player
Hooking up 2 additional monitors..
you can try to use a y splitter. the problem with that is the receiver will not give you enough "power" to power up the headrest. You will probably lose picture quality. There are amplifiers that can be purchased that will have extra outputs for video, this would be your best bet. It will give you great picture quality.
May 18, 2010 | Kenwood Excelon DDX-7015 Car DVD Player
Ipod hook up
YES you can!! Touch the "video" button on Jensen, theyou MUST use your iPod to findthe video you want to play on the screen and SET YOUR iPOD SETTING TO "TV OUT"!! I have the same decand iPod and it's GREAT!! Just remember that on videos, set the iPod to TV OUT, and control the video from the iPod!!
Enjot man,
Larry T
Winona Lake, IN
Jan 22, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Car staereo tuner
ha ha ha ha i only laugh because i now know whats wrong with your system the same thing that was wrong with mine ok cue to the sound not comeing on you have a external amp , you should well anyways just disconnect the remote wire the blue wire that you had first hooked up now connect the second blue wire to the remote wires for the the amps now when you play dvds or cds you will now be able to hear due to the remote always sending signal instead of signal from the radio which is for the antena if you wer to have an electric one
Mar 14, 2008 | Kenwood KVT-617DVD Car DVD Player
Tv tuner for vm9410
Mar 01, 2008 | Jensen VM9410 Car DVD Player
Dual xdvd710
If you can find a separate tv tuner with remote the run it through the unit rear input. But stand alone tuner is rare if it even exist. Search Ebay to see if you can find one. There is another way by hook up a small portable tv with video/audio output and use an adapter from RadioShack to send the signal to rear input of the unit, but picture and sound quality is only as good as the reception of the tv. Goodluck.
Feb 10, 2008 | Dual XDVD8181 Car Video Player
Car Video Players Logo
16 people viewed this question
Top Alpine Car Video Players Experts
Jaime Hernandez
Are you an Alpine Car Video Player Expert? Answer questions, earn points and help others
