Question about Wellness Ijoy Ottoman 3.0 Microsuede & Faux Leather
Ijoy ottoman 3.0 turns off by its self after a few seconds
Have a i joy ottoman 3.0 turn it on and it shuts off bybit self after a few seconds
My i joy 100 runs for 5 seconds then shuts off
Hi there Kevin. Did you find the problem? I have the same problem to and I don't know what to do :/
Nov 18, 2013 | Human Touch Ijoy 100 Robotic Massage Chair...
Will Not Turn On
First you need to do a self test diagnosis and then if it comes up with:
SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Do self test by pressing Input/Device and Menu at the same time for 5 sec. the set will show a 2 digit seq. first blinks followed by a short pause then the second.
Dec 29, 2007 | Mitsubishi WS-65807 65" Rear Projection...
My 1993 nissan sentra 1.6 wont run and check engine light wont turn on,bulb is ok
Could be any of several things. If the crank sensor is marginal and not sending pulses, the fuel pump is shut off. This is for safety. The pump is energized for a few seconds as key is turned in preparation for starting then engine must rotate normally to keep the pump on. If it stops, in a few seconds the fuel is cut off.
Aug 17, 2012 | 1993 Nissan Sentra 4 Door
Oven Stuck on Self-Clean/Locked cannot undo
you can press the clear off button for 3-5 seconds this should turn off the oven. if not turn off the circuit breaker for a few minutes then turn it back on and hit the clear off button again
Feb 27, 2010 | Ovens
Pinches calf
also can cause blood clots......
Jul 31, 2009 | Wellness Ijoy Ottoman 3.0 Microsuede &...
My emerson tv is turning it self off
my tv shuts off after a few seconds what can i do to fix it
Sep 12, 2008 | Emerson EWL20D6 Television
Wellness Ijoy Ottoman 3.0 Microsuede & Faux Leather Logo
53 people viewed this question
Top Wellness Health & Beauty Experts
Marvin
Marvin
JonSnell Electronic
JonSnell Electronic
Are you a Wellness Health and Beauty Expert? Answer questions, earn points and help others
