Question about Sony KP-51HW40 51" Rear Projection Television
Sony KP-511HW40 - blue/green tint issue - convergence issue?
Hi - starting yesterday, our TV is having a blue and green ghost, shadow issue on the picture. Not sure how to explain. When I put a DVD on and put it on Pause, the 'PAUSE" message is showing twice, once as regular shows "PAUSE" again in blue.
Please help!
Sanjiv
  • Sony Master
  • 5,138 Answers
Replace your convergence ICs STKs big black ics Go by number on them STK392-560 ect..... Parts you can order on line www.electronix.com or Call 1-800-223-3205 you will also need silicon heat sink compound to put on New ICs replace Both STKs
Posted on Dec 27, 2008
I have a sony kp-51ws510 projection tv, i replaced the convergence ic's and a pico fuse and then reset the convergence. The tv looks good except for a green shadow on lettering, also on the convergence...
Did you check the two pico fuses on the G board? Usually at least one will blow when the original ICs failed. I am attaching a pic that shows the 2 pico fuses on the G board.
Jul 08, 2011 | Sony KP-51WS510 51" Rear Projection...
Hello, I have a 2005 Sony KP-51WS520 Rear Projection TV. Recently, the green colors all become a yellowish/orangish color. When you are watching a baseball game the grass is a orangish color. ...
DLP tvs have a design weakness,the problems it is call a convergence problems,it is dead.This convergence problems,will have happen many times through out the tv live.The tv have a colors R,G,B lines misalignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv board,that call the tv convergence board it is dead.The tv convergence board,must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv colors picture convergencce problems.The tvs shops will cost u like $300-350 for parts and labors.
May 24, 2011 | Sony KP-51WS520 51" Rear Projection...
My sony KP-46WT510 has double images and the edges are red and green
Try pressing the Flash Focus button on the TV to adjust the convergence of the TV.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 22, 2010 | Sony KP-51HW40 51" Rear Projection...
Tv turns on but has a shadow around evrything
Do you have any speakers or magnets next to the tv? If so, that is not good.
It may be a convergance issue. Check to see if you have any adjustments on the back of your tv to adjust picture. If not, if may be a faulty capacitor that needs to be replaced
Jul 02, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KP-43T75 color repair
This link has the instructions on how to fix this problem and other similar problems. You have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection TVs have the red, green, and blue pots in the same order as the picture that is listed on this link, so you may want to google search for your model's service manual. The service manual can also help you be able to remove the cover for your particular model of TV. I was able to find the service manual for my model, and sure enough, the order of the pots are reversed on mine, so I would have been adjusting the wrong color. Read all of the comments on this link too, because you can find other helpful tips and may even find someone with the same model of TV as you that gives more specific instructions for your model.
You may also find your model's service manual here:
http://esupport.sony.com/US/perl/index.pl
I hope this helps you!
Fare well. :)
Iconoclast
Jun 27, 2009 | Sony KP-51HW40 51" Rear Projection...
Shadow
The sony convergence Kit Type 1 available at the following link will usually repair that issue. The kit contains the parts plus a CD with detailed instructions to do the repair.
www.tvrepairkits.net
Jun 25, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony kp-48s75, shadow or ghosting picture
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 07, 2009 | Sony KP-48S75 48" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
112 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
