Question about AudioBahn ALUM12 Car Subwoofer
Have two alum12qa
I have two alum12q's subs. And i have a 1 ohm mono amp. The subs are dual 6 ohms. And if i run them in parallel mode how would i do that. And seeing that there are 2 positive and 2 negative post on each sides of both sides(8 posts on each sub). Do i have to use all the posts? Since my sub box has two chambers, I was jus gonna run the left side positive to the right side positive and then to the terminal box. And do the same wit the both negative sides. And the to the other side. Then i was gonna get another cord and run it to the amp and have a positive and negative cord coming from each side of the box and put all the negatives together and the same wit the positive. Would that be a good installation. or do i have to run the two subs directly to each other instead of letting the meet up outside the box.
  • rsaaml Nov 05, 2007
    trying to parallel my alum12q subs to my mono amp can someone help?
  • 4 Answers
SOUND Q SERIES
DUAL 6-OHM CONFIGURATION
Accommodating the rising trend of triple-subwoofer applications, Audiobahn’s Sound Q subwoofers come in dual 6-ohm configurations. This allows three Sound Q subwoofers to be wired in a 1- or 4-ohm operation. You now have the option to use a wider range of amplifiers to fit the needs of your specific application.
MULTI-CONNECT LUG LOCK TERMINALS
Audiobahn’s patented Multi-Connect Lug Lock Terminals offer increased versatility in wiring multiple subwoofers to an amplifier or to another voice coil. Multi-connect terminals allow you to use single wire connections in each terminal rather than combining multiple wires into one terminal. This feature allows you to use a full 8-gauge wire in each terminal.
COMMON FEATURES
Dual 6 Ohm VOICE COIL
Multi-connect Lug Lock Terminals
The Link below should answer all your questions.
Also remember to try to keep the lengths of the jumpers the same. I would make all the connections inside the box then use the teminal block of the box to connect to the amp.
Keep in mind that you can only get 1 Ohm if you use 3 woofers.
Your configuration allows for 1.5 Ohm
http://www.audiobahn.com/Audiobahn06/images/tech/wiring/parallel_parallel_dual_6.pdf
Good Luck
Posted on Mar 04, 2008
Bridge 2 10's to a 2channel amp
most times it is L+ and R-. If the amp is bridegable. Also, make sure you don't go to low in the ohms. If your amp only runs at 4 ohms mono. Don't bridge it down o 2 ohms mono. If you have dual voice coil subs. bridge the coils of the subs in series, then bridge the two subs outside the box parallel.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Dec 25, 2014 | Car Audio & Video
I have Sony xm-2165gtx amp 165 watt rms x 2 at 4 ohm 200 watt x 2 at 2 ohm 400 watt x 1 bridge output at 4 ohm stereo or bridge mono output 4 ohm stable in bridge mode this mean can't go lower then 4 ohm...
You can't bridge that amp onto a load lower than 4 ohms. So you can't bridge that amp onto two 4 ohm subs. To get the most power out of your subs is easy. Run one channel to one sub and the other channel to the other sub. 165 watts RMS is plenty for most subs.
Dec 05, 2013 | Car Audio & Video
Wiring a crossfire vr602 at 4ohm
OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
I have an old soundstream reference class a 5.0 and a set of mb quart pwe 254 10 duel voice coil subs. i would like to know how to wire this set up for the most power. parrallel the voice coils then run...
The Soundstream Class A 5.0 will deliver its full power at 1 ohms mono.
I think your subs are two dual 4 ohm voice coils.
If you wire the voice coils for each sub in PARALLEL, that's 2 ohm for each sub. To get 1 ohm mono, you need to hook up the subs in PARALLEL to the amplifier, in bridge mode. That's the way to get to 1 ohm mono. Please add a fan to your setup as the amplifier will get very hot. You will need to use a relay to hook up the amplifiers and fan(s) to or you will damage the remote ouput of your HU (if you hook up the fan straight to the remote of the HU) as the remote output of the HU is not designed for the amount of current a fan draws.
Good luck. If you need help with the relay issue, have a look here: http://www.caraudiohelp.com/newsletter/multiple_amplifiers.htm
Jun 27, 2011 | MB Quart PWE-254 Car Subwoofer
I have an alpine cda9831 unit with 10" subs. I have an alpine v power m500 independently running them. The subs will randomly cut off and on and the wires to the head unit have been checked for loose...
so you have already ensured that there are no crossed/loose wire strands.
you are running 2 subs off a single alpine mono amp.
if subs are 4 ohms apiece, you should be fine. if you have 2 ohm subs, or you have dual voice coil subs and you are running all the voice coils parallel, then there is your problem. you can have a maximum of a 2 ohm (2x4 ohm speakers= 2 ohms.) load with that amp.
ensure that the subs are 4 ohms apiece, and that you are not using dual voice coils. if the subs have 2 inputs (dual voice coils) then only use 1 input apiece.
if this is already taken care of, then your amp is defective.
Nov 06, 2010 | Car Audio & Video
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
I have a JBL GTO 1201.1 mono amp and I have a kicker L5 solo baric with dual 2 ohm coils how do I run it to get the full power out of my amp?
You will not be able to get the full power from the amp without ruining your sub. The amp puts out full power into a 2 ohm load so option -A- is to just run one coil off the sub and it will absolutely pound -until you roast the coil.Then you can use the other coil and roast that one too. But since you do not want to roast anything-first thing to do is take it to the store and trade it in for a dual 4 ohm sub-wire the coils in parallel and there's your 2 ohm load to achieve max power from the amp. Problem there is that you will have WAY too much power for the sub to handle and you'll blow it anyways (in time).Best thing you can do is get an identical sub(dual 2-ohm) wire the coils in series which will make them 4 ohms per sub then parallel the subs to get back down to 2 ohms overall-you get max power from the amp and hopefully enough speaker to handle it.Hope that helps.
Feb 13, 2010 | JBL GTO 1201.1II Subwoofer Mono Amp Car...
How to connect HIFONICS BXI 2607 D watt at 1 ohm....
That's dependent on your subwoofers. You will need 2 dual 4 ohm subs wired in Parallel, a single dual 2 ohm subwoofer wired in parallel, a single dual .5 ohm wired in series. Or something similar.
http://www.bcae1.com/spkrmlti.htm
Nov 20, 2009 | Hifonics BXi 2006D Mono Block Amplifier...
500/1 settings to run jl13w6 v2 d-4
Just had a look at both amp and sub on the JL Audio website. The amp runs from 1.5-4ohms. 4ohms at 14.5V. The sub is running dual 4 ohms coils. That's what the D-4 means. So should be an easy set up. The amp has two mono outputs, so one for each coil. It looks like the perfect wattage to run the sub real nice.
Web page for amp: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Web page for sub: http://mobile.jlaudio.com/products_subs.php?series_id=18
Nov 19, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Dual voice coil wiring to class d amp
The easiest way to think of wiring voice coils and subs is this:
  • Two items of the same impedance in parallel = Half of the impedance
    • 4 ohms in parallel with 4 ohms = 2 ohms
    • 8 ohms in parallel with 8 ohms = 4 ohms
  • Two items of the same impedance in series = Double the impedance
    • 4 ohms in series with 4 ohms = 8 ohms
    • 8 ohms in series with 8 ohms = 16 ohms
In this case, you want to wire two subs, each with dual 4 ohms voice coils, so that the total equals 2 ohms. Your options are:
  • DVCs in parallel, 2 subs in series = 4 ohms
  • DVCs in series, 2 subs in parallel = 4 ohms
  • DVCs in parallel, 1 sub = 2 ohms
With two, dual 4 ohm subs, you can only have 1 ohm or 4 ohm total impedance.
Mar 16, 2008 | Car Audio & Video
AudioBahn ALUM12 Car Subwoofer Logo
306 people viewed this question
Top AudioBahn Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jerry Naidoo
Robert Rankin
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
