Onda touch vx747(ithink) wont turn on
Its christams day i open my onda adn i liek it turn it off put some robot chichken and music on there tehni run the files it wroks
well then i tunr it off again( then put soem more msuic on it) i later tunr it back on then later when i try to tunr it off it took forever to turn it off i had to hold the switch alot then after that i couldnt tunr it on
  • jane93 Feb 01, 2009
    My onda vx747 is frizen and I cannot do a thing with it but put in the bin, only had this for 2 months. Can anyone help please
    jayne
  • jh51 Mar 14, 2009
    I tried to download firmware updates to my Onda touch vx747 before letting it charge full ONE good time. NOW IT WON'T TURN ON.
4 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: ONDA mp3/mp4/PMP maker
Noted :-)
Posted on May 25, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: how to use my onda vx858 mp4
If it's an Onda, then it's a custom build. I would see if you can get Windows Media Player to recognize it, and then sync files to your device that way. If not, just connect it to PC, double-click my computer, and double-click the Onda device. If it has a msuic folder, just drage your files to there. I would only drag mp3-formatted files to this player - since it is a custom build, there are no specs. Here is a link to the company website:
http://www.ondacorp.com/products_custom.html
Custom builds are not for rookies. You are THE expert in this product simply because you own it.
Posted on Sep 07, 2008
SOURCE: onda vx767 mp4
Hi. I have a 767 (Onda not Boeing :-) ) Mine has crashed like this a few times. Once the power drains to empty you should be able to start it after a charge. Sometimes pressing a pin through the reset hole will work, sometimes not.
Posted on Mar 25, 2009
Problem with V. 811 Onda Tablet
hi Akram.
this is all i could find out.
When the tablet is turned off, keep home button pressed.
Now turn on tablet while still holding the home button.
When white android figure appears, release both buttons.
You will get into recovery mode, you can select "restore factory settings" there.
Download the right firmware here: ONDA
Extract the content to the root of your sd card (since you cannot use your tablet, i suggest using a cardreader + pc or another tablet? or try to hook your tablet to the pc and hope it recognizes it)
There should be 5-6 files now on your SD card.
Turn on tablet while holding home button, untill white android figure appears then release.
It should update your firmware now...
or you could try this link on how to do a hard reset.
but do so at your own risk.
Onda V811 hard reset format factory mod recovery rom install ..
or try this link for more info.
hard reset tablet onda v811 Google Search
or this one.
811 Onda Tablet logo screen white Google Search
Nov 27, 2017 | Tablets & eReaders
Hey I have a Vi30W onda tablet but when I try to turn it on it stuck with the android logo and I dont know how to actually turn it on.
it sounds like you're at the emergency recovery screen, volume down to see the first menu, select option 1 reboot device, do not select anything else.
Dec 27, 2013 | Onda Vi30W 8 Inch Capacitive Screen...
Onda v711
You need to perform a hard reset on your Onda V711. Here`s how: You can perform a hard reset by booting into a special recovery mode. First, ensure your device is fully shut down. When the tablet is turned off, keep home button pressed.
If that fails, try flashing new firmware.
May 03, 2013 | Tablets & eReaders
My tablet onda V971 stuck at android logo at startup
HI. My name is Hammad. I was facing same problem. I cnnect usb cable to my laptop and other end to my onda v971 tablet. Then I power it up. It starts in first try without any problem. Try it
Nov 05, 2012 | Onda vi10 7" TFT Capacitive Screen Android...
My speakerphone doesn't work. How can I check it?
That will be your microphone not working then. Have you tried doing a reset? Hold down Home and Sleep buttons together.
I'm recently trying lapel microphone
Aug 07, 2012 | Onda Vi10 Android 4.0 Tablet Pc Mid 512mb...
I need an english onda VX570 User Manual
The Polaroid pmp500-4 HD Touch is the pretty close to the same as the ONDA and the manual located here could meet your needs
http://www.southerntelecom.com/polariodsupport/downloads/PMP500.pdf
Nov 07, 2011 | Audio Players & Recorders
Onda & ACER Connectivity issues
Problem is considered as "solved" as both ONDA & Vodafone.gr supports CONFIRMED in written that specific brand new and capable for even 10 mbps maximum speed usb 3g mobile modem CANNOT SURVIVE IN A ACER IN GENERAL and no existing microsoft or ACER patch solves that !
So vodafone is thinking now with what (and compatible to new ACER's) will CHANGE my ONDA !
So consider that solved !
THO BE AWARE THAT NO FIX SOLUTION EXIST ON SUCH A CASE
Oct 14, 2009 | Acer Aspire 3000 Notebook
How to use my onda vx858 mp4
Sep 07, 2008 | Audio Players & Recorders
Onda vx767 mp4
OK, so you plugged the car charger for the FM transmitter into your Onda player headphone jack perhaps? Yeah, that could cause problems. On the one hand, this player needs to be replaced. You can e-mail Onda by going to the crappy US version of the website - they seem small and they seem like custom-builders. On the other hand, they may have an inferior web page because there are no US contacts at all - they may all be Chinese. Most products have a warranty, but even better, most stores have a return policy. A US-based repair service would cost a minimum of $279.00, and that is assuming that they would be able to fix it (which they probably can't).
If you have already tried a reset suggested by the manual, and there is no "recovery" method listed in the manual (which would just be a version of what I gave you before, except they may suggest a button other than volume +), then I would go ahead and return it - sorry.
Jun 12, 2008 | Audio Players & Recorders
124 people viewed this question
 Grubhead
Grubhead
