Question about Nintendo Mx vs. ATV Untamed Wii for Wii
Atv on our sons atv the trottle is stuck ,when you start it ,it just goes full blast
  • Brad Hurt
    Brad Hurt May 11, 2010
    An you be more informative.What brand,size and model of ATV
  • 51 Answers
Lube the cable. a simple google search on how to do this will solve the problem.
Posted on Aug 01, 2009
    Problem Solver:
  • 16 Answers
I had the same problem, what i did was opened up the houseing of the throtle which is on top of the handlebar. just open that up and spray some grease.
Posted on Jul 24, 2009
Yamaha not start
I would not think so
check for broken wiring, kill switch and dirty terminals and connections
Jun 15, 2014 | RTO 125cc ATV Quads Full Size Adult four...
06 king quad spark fails while riding
you are fouling spark plugs. the atv is running way too rich. either the air filter is super dirty or exhaust has been modified (race pipe, baffle removed, etc)
if none of those have been done then maybe your carburetor needle is stuck open and is flooding the motor and the carb needs cleaned.
Mar 31, 2014 | ATVs
Where do fuel lines go ? when i turn on the gas fuel runs out on the ground
it goes into the carburetor, if the float is stuck in the carb the gas will continue to flow out of the overflow hose
Sep 15, 2012 | RTO Quads 125cc Full Size Adult 4 Wheelers...
Air conditioning not turning off
This is due to the fact that the solenoid relay is stuck and so the ac is not cutting off. You need to open the hood and check after starting the car. If the fan is cut , does the ac cut off, if not the relay or the solenoid of the compressor must be checked.
Jul 03, 2012 | 2010 Nissan Sentra
I have gas in my oil and it wont trottle,idles fine but back fires when u try to trottle up(threw carb).
it sound like the needle and seat might be slowly leaking by causing it too flood down the carb and in too the oil if your oil is not over full and just has some gas in it your exhaust lobe may be worn on the camshaft causing the backfire you try too throttle it
Dec 29, 2010 | Polaris ATV
49cc 2 stroke runs for 20 sec. then cuts out
20 seconds is all that is required to drain the float bowl. You have a float bowl/needle valve problem.
Apr 24, 2009 | Fender 2 Stroke Full 49cc ATV # ATG-47B...
Full trottle when i start my 4cyl rodeo it,s a 4cyl manual tran
check throttle linkage i think you'll find it stuck wide open.
Nov 16, 2008 | 2000 Isuzu Rodeo
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Nintendo Mx vs. ATV Untamed Wii for Wii Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
