Question about Lexmark X2500 All-In-One Printer
Scanner will not scan! Instead it prints the test print page...
I hold down the scan button and it will not scan! It just prints the test page or asks for paper
  • 126 Answers
Reinstall the drivers and try again
If not it will be a faulty model and you will need to return it
Posted on Dec 25, 2008
I have a epson s20 printer. The printer go,s through the process, the paper passes through the machine, but the paper is blank.
Is the ink cartridge empty? Try changing ink cartridges. Is it only 1 color that is not printing? That might be the empty one. Most home inkjet printers have only 1 button a power button. If you shut it off then turn it on but hold down the button it may print some kind of test page. If there are any other buttons you can try holding down different combinations to see if it prints a test page.
That would eliminate any problem from the computer being the cause of the issue.
May 02, 2011 | Office Equipment & Supplies
I have an hp 3150 all in one printer. Every time I turn it on to print a document it prints a test page. I am out of color ink so it doesn't print the additional numbers and lines to align the printer. I...
I know your problem and i want to know that have you changed or refill your cartridge?.
if yes
place one plain paper in the tray.
it will print the test paper
print it and place it on the scanner with the printed side down.
press the scan button from the printer
printer will blink the light for some time and stop blinking
now it didn't print test print every time you print
thanks
Jun 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
Printer states "out of paper" when there is a lot of paper in the carriage. Have pressed "Print" button 5 or 6 times, so.....how do I clear all the print requests, and reset the printer to recognise that...
Please perform the following steps and check if the issue is resolved.
1. Please try to Printer a Self Test-page.
>Please press the Power button to turn the product on.
>Hold the Power button down.
>Continue to hold the Power button, and then open and close the carriage access door four times.
>Release the Power button
>Now, try to print a self test page and check if that works.
If the self test page does not works/print a test page, clear the paper jam.
Also, clear the paper rollers and if this does not work, perform a power reset to resolve the issue.
You can refer the link below to get the complete information to perform all the steps mentioned above.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00861130&cc=us&lc=en&dlc=en&product=3374275
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02125514&cc=us&lc=en&dlc=en&product=3374275
Good Luck!!!!
Jul 02, 2010 | HP D1560 Deskjet Printer InkJet
The HP Photosmart c3180 prints a color test sheet every time I turn it on even if only to scan a document. How do I prevent it from doing this?
1. Turn on the HP all-in-one.
2. Disconnect the USB cable from the all-in-one.
3. Press the sequence of front panel buttons below to initiate the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
a. Press and hold Cancel.
b. While holding Cancel, press On.
c. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
d. Press Cancel again.
e. Press Copies.
f. Press Paper Type.
g. Press Color Start Copy.
h. The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
4. Once the alignment page is printed, place the page face down on the scanner glass and press Scan. The alignment is complete when the On light stops blinking. 5. Reconnect the USB cable.
Mar 15, 2010 | HP Photosmart C3180 All-In-One InkJet...
How do I deselect "print a diagnostic
you need to calibrate print head, look up to your manual, or try to place the printed test page in the scanner printed side down and hold scan button, after scan, problem should be solved
Jul 10, 2009 | HP Photosmart C3180 All-In-One InkJet...
How do I get a alingment test
HP PSC 1200 and 1300 series:
  1. Turn on the HP PSC 1200 or 1300 series product.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
Jan 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
Will not print test page or documents
  • Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
  • While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
  • Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
  • Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
  • Press the PAUSE button. The printer begins printing the self test.
  • To stop printing temporarily, press the PAUSE button.
  • To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Jul 04, 2008 | Office Equipment & Supplies
Blank paper
Make sure you are letting it warm up long enough.
Brother HL-2140 Support
Jun 16, 2008 | Brother HL 2140 Laser Printer
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
      5. Press Copies .
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
Hp psc 1410v
Could be a number of things. I would try looking in printer settings first. Click on your printer, go to properties and check all settings, it may be set to do this or similar. If no go, try uninstalling and reinstalling it, or just turning it off and unplugging, replugging and turn on again can often reset irregulariites. Also try resetting default printer settings too.
Apr 07, 2007 | HP PSC 1410v All-in-One Printer
Lexmark X2500 All-In-One Printer Logo
43 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
