Question about SanDisk 4GB microSD High Capacity Memory Card
Doesn't load My 4gb micro sd card doesn't show up on my computer when i put it in.
  • 2 more comments
  • insane_boy Feb 16, 2009
    i try to put it in my phone or in the adapter but neither of the two show work the phone shows up but the memory card doesn't show up on the drive!!!!!!!!!!!!!!!!!!!!!!
  • renagade1982 Feb 28, 2009
    i'm trying to up load mp3's to my card but the computer insists there's an i/o error
  • Anonymous Mar 15, 2009
    Hi everyone,
    I have a SanDisk 4GB microSDHC card and my computer does not show up on My Computer. How do I fix this problem so that I can start downloading onto it
  • dandaboydand May 10, 2009
    i cannot open my kingston 4gb memory card on my vista,pls help
  • 126 Answers
The reader may need re-iinstalling. or the port you are putting it in is incorrect,. try another stick to test the port or try the memory card in another PC to confirm the stick is OK
Posted on Dec 25, 2008
My sd card does not show its property and doesn't format it?
normally when this occurs, its means the SD card is dead and u will need to replace it.
try connecting the sd card into a different computer or another external SD card reader. If it shows up . right click and click format. If it says it cant format it it means the card needs to be replaced.
Dec 30, 2012 | Skque 4GB MicroSDHC / MicroSD / Micro SD...
How do i shut off write protection
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 16, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card is locked how to unlock
Aug 12, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card get write protected help me to retrive it...
I hope this helps.
Aug 10, 2011 | Computers & Internet
When i try to format my micro sd card system shows remove write protect how can i format it
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
How do I upload pictures from my Samsung Strive onto my Gateway laptop comuter.
1. Purchase a micro-SD card with an adapter for a normal-sized SD card.2. Plug in the micro-SD card to the back of the phone. Make sure the power is off when you do this, of you could unintentionally harm your phone.3. Power back on, and transfer the pictures to the micro-SD card.4. Shut the phone back off and remove the card again. Place it into the adapter.
If your Gateway laptop has a SD card reader:
5. Put the adapter into there.6. Transfer the pictures to you computer. Done!
If your laptop doesn't have a SD card reader:
5. You'll need to purchase a second adapter that adapts the regular-sized SD card to a USB port.6. Following the manufacturer's instructions, put the SD card into the second adapter.7. Transfer the pictures to your computer. Done!
Best of luck, Juseppi
Jul 09, 2011 | Samsung Strive A687 (88516535667)
I have a kingston micro SdHC card 4gb and when i try to copy a image or a mp3 file from my laptop i can't because of the error 0x8007045D...
Make sure the little white switch on the side isn't set to write protect the SD card. Try and format the SD card, it will erase whatever is on the card. To do this right click the SD card removable disk under my computer, then click format. I would make sure you select FAT16 in the options there. Then try to copy files to the card again. If it still doesn't work, try using the SD card in another machine.
If the card works in another machine, we know the SD card is good. If it doesn't work, you might have a bad card.
If the card works in another machine, try another SD card in your laptop, to make sure the laptop connector for your card is not bad.
May 02, 2011 | Kingston 16GB MICROSDHC CLASS 4 W/2...
Sansa c240 and a 4 GB Micro SD HC card.
Sansa C240 can only read SD cards that are NOT SDHC - that means it can only read up to a 2gb Micros SD card.
Jun 05, 2009 | SanDisk Sansa c240 MP3 Player
File Explorer won't show SD Card
the PVR-H140 unit doesn´t support the SDHC cards, only the old fasion SD cards are supported, sorry :(
Sep 30, 2007 | Mustek PVR-H140 Digital Media Player
SanDisk 4GB microSD High Capacity Memory Card Logo
467 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
