Question about Acer Aspire 5500 5570-2609 Laptop
DC input jack broken
The DC Input jack for my Acer Aspire 5570Z is broken, rendering the machine useless. Could you please advise which part needs to be replaced and a site where I could find the part for purchase online. The machine has been at the repair shop for over 7 months now, I need to solve this ASAP.
Regards,
Keith
  • 502 Answers
Yes it's not usually something that can be repaired at home. Your chances are better if the jack just seems loose and not actually broken, however replacing it is better. I work for a Laptop Repair Shop in NYC and we deal with this issue frequently.
Posted on Mar 14, 2009
  • 144 Answers
Unless you have very good soldering skills and knowledge of dismantling a laptop etc , take it to a repair shop and get it done. It only takes one wrong move if you attempt this yourself.
As for the replacement part you need a "DC Power Jack"
Search on ebay for your model - most shops should reduce the repair fee if you have the replacement part already
Sometimes the old jack just needs resoldering on , but it is better to completely desolder the old jack from the motherboard , then resolder on the new jack
Remember , if the laptop works in any way , or did do before it broke , i recommend taking it to a repair shop as DC jack replacements is probably the hardest laptop repair there is.
Posted on Dec 29, 2008
DC jack for aspire 8943g
Just go to any electronic shop and bring the sample jack, surely they have one for you.
Hope that helps!
Nov 23, 2011 | Acer Aspire Ethos 8943G-5464G50Bnss...
I have an Acer aspire 4551-2615 Laptop thats not charging. When the adapter is connected to the charging port, the power led does not display any signs of power. i Have tried a different power adapter but...
The chances are that the power jack on the motherboard has been separated (broken). If you are good at microsoldering you could try to repair it yourself. The safest bet is to take it to a laptop repair shop where they can replace the jack. This is a common problem due to the stress on the jack.
Let me know if you have any other questions. Thanks.
Sep 28, 2011 | Acer Aspire 4551 Notebook
No power at all, tried a new charger still no power and replaced the battery.
Hi
After the battery and AC cord replacement and still not getting power there's only once culprit there and that is the motherboard of the laptop. I recommend you call Acer and have them replace it for you. Thanks
Feb 21, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
Acer 5570z will not boot up or turn on
It could be one of the following:
1. Bad/damaged power jack.
2. Bad motherboard.
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 26, 2010 | Acer Aspire 5570-2067 Notebook
Battery not charging
two possibilities:
1. AC adapter is not working well. 2. laptop DC power jack loose or broken
most likely 2, quite common for laptop, Acer
try if you can power on your laptop only with the AC adapter without the battery;
also keep monitor the indicators on your front panel, see if the AC input is on.
Dec 05, 2009 | Acer Aspire 5570-2758 Notebook
My ACER 5570z will not start up. When power cord
You most likely have a broken DC Jack on the motherboard. Thus, the battery cannot get a charge and the power supply is not making a connection to the system board because of the broken DC Jack.
Good Luck
Sep 29, 2009 | Acer Aspire 5500 5570-2609 Laptop
you need to buy a new jack for replacement. then solder the broken one out of the mainboard and clean the place and solder the new one. or some acer have a separet jack then that one is easy only to change.
Dec 25, 2008 | Acer Aspire 5500 5570-2609 Laptop
DC power input center pin is gone
Part costs about $ 5-10 bucks.....labor to fix it ranges from $ 100 - $250. Problem is caused by jerking or tugging on the power cable too much. All laptops need a Cable Retention Device like the one in this video. . .
Jan 05, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 1360 d/c input port
I have the exact same problem, the dc jack port pin as come off of the motherboard circut..so I do not know where to even try to solder it. I hate their input jacks, the laptop, a Acer aspire 5570, is only 6 months old, and useless, because i cannot charge the battery or use the charger directly. What a poor design, designed to wear out. So I just end up buying a stand alone external battery charger online from www.portatechs.com at least i will be able to charge the battery and put it in the laptop
Nov 29, 2007 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
406 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
