Question about Acer Aspire 5500 5570-2609 Laptop
DC input jack broken
Hello, The DC Input hack for my Acer Aspire 5570Z is broken so the machine is totally useless. Could you advise which part I need to replace and where I could purchase it online?
I have had it in the repair shop for over 6 months now
Thanks
Keith
  • 1 more comment
  • Anonymous Dec 28, 2008
    I hate this computer the input jack has broken 3 times. You have to send it in to be replaced. It costs $200, and to get insurance on the computer is another $200. I didn't think it would break twice. I guess i just underestimated what a truly terrible product it was.
  • Anonymous Jan 22, 2009
    oh jesus I have the same problem, it's broken 4 times already for me and I don't even move the laptop from my desk. Acer really sucks!
  • bbaalloonn
    bbaalloonn May 11, 2010
    how do you know that the input jack is broken? mine won't turn on and won't charge..is it because of the input jack too?
  • 69 Answers
You need to buy a new jack for replacement. then solder the broken one out of the mainboard and clean the place and solder the new one. or some acer have a separet jack then that one is easy only to change.
Posted on Nov 11, 2012
  • 335 Answers
Hi keith,
On most acer laptops, the dc input jack is soldered directly to the mainboard, if this is the case, you need a new mainboard ($$) Some of the acer laptops from this series have a separate circuit board with the dc jack and a couple of usb ports on it. Call acer tech support to see if your laptop has a "DC USB BOARD" part available for it. if so, order it as it will probably cost under $20
Hope this helps
Posted on Aug 09, 2009
DC jack for aspire 8943g
Just go to any electronic shop and bring the sample jack, surely they have one for you.
Hope that helps!
Nov 23, 2011 | Acer Aspire Ethos 8943G-5464G50Bnss...
I have an Acer aspire 4551-2615 Laptop thats not charging. When the adapter is connected to the charging port, the power led does not display any signs of power. i Have tried a different power adapter but...
The chances are that the power jack on the motherboard has been separated (broken). If you are good at microsoldering you could try to repair it yourself. The safest bet is to take it to a laptop repair shop where they can replace the jack. This is a common problem due to the stress on the jack.
Let me know if you have any other questions. Thanks.
Sep 28, 2011 | Acer Aspire 4551 Notebook
The adapter doesn't seem to connect right. I was told it was inside the computer, but I'm not sure if the guy who was looking at it really knew what he was doing.
There are a few ways you can solve this, 1. Get someone to test the adapter in there laptop providing it is the same output and plug connection, 2. use a voltage meter on the charger unit or take it to a shop to be tested. If the DC socket on the laptop is broken then you can replace one for around £5 gbp
http://cgi.ebay.co.uk/Acer-Aspire-5610Z-5570Z-5070-5100-DC-Jack-Power-Socket_W0QQitemZ170473400574QQcmdZViewItem?rvr_id=151188800698&rvr_id=151188800698&cguid=8ffd742512a0a0aad2073257fd1ddf26
This will need to be soldered too just a few wires not too difficult if you have soldered before.
Good Luck
Oct 06, 2010 | Acer Aspire 5100 Notebook
Acer 5570z will not boot up or turn on
It could be one of the following:
1. Bad/damaged power jack.
2. Bad motherboard.
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 26, 2010 | Acer Aspire 5570-2067 Notebook
Battery not charging
two possibilities:
1. AC adapter is not working well. 2. laptop DC power jack loose or broken
most likely 2, quite common for laptop, Acer
try if you can power on your laptop only with the AC adapter without the battery;
also keep monitor the indicators on your front panel, see if the AC input is on.
Dec 05, 2009 | Acer Aspire 5570-2758 Notebook
My ACER 5570z will not start up. When power cord
You most likely have a broken DC Jack on the motherboard. Thus, the battery cannot get a charge and the power supply is not making a connection to the system board because of the broken DC Jack.
Good Luck
Sep 29, 2009 | Acer Aspire 5500 5570-2609 Laptop
Yes it's not usually something that can be repaired at home. Your chances are better if the jack just seems loose and not actually broken, however replacing it is better. I work for a Laptop Repair Shop in NYC and we deal with this issue frequently.
Dec 25, 2008 | Acer Aspire 5500 5570-2609 Laptop
DC power input center pin is gone
Part costs about $ 5-10 bucks.....labor to fix it ranges from $ 100 - $250. Problem is caused by jerking or tugging on the power cable too much. All laptops need a Cable Retention Device like the one in this video. . .
Jan 05, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 1360 d/c input port
I have the exact same problem, the dc jack port pin as come off of the motherboard circut..so I do not know where to even try to solder it. I hate their input jacks, the laptop, a Acer aspire 5570, is only 6 months old, and useless, because i cannot charge the battery or use the charger directly. What a poor design, designed to wear out. So I just end up buying a stand alone external battery charger online from www.portatechs.com at least i will be able to charge the battery and put it in the laptop
Nov 29, 2007 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
491 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
