Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Kenmore whispertone 8900 won t turn on
Need manual to know how to take apart to check motor...I don t want to
break the covers...
model 116-3289090c
  • Anonymous Jan 04, 2009
    Kemore Model No. 116. 27616700. White Powermate Progressive. Less than a year old.
5 Suggested Answers
Agent Don
  • 310 Answers
SOURCE: The shaft on the motor
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=661780
Generic problem for all Vacuums
Posted by tsnater on Jun 10, 2008
The shaft on the motor for rotating the brush is not moving. It is a Kenmore Whispertone 12 V Model 116 3521290.
I am suspicious of the Belt Protection system.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you have a motor that is froze up and would be in need of some type of service, whether it be the fan(s) on the end of the motor, the carbon brushes are sticking and bound up, or the armature would be the last thing. Just be careful that the repair cost and labor do not exceed the cost of a new motor. The motor shaft should @ all times should spin freely. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
  • 70 Answers
SOURCE: Kenmore 3.9 with power-mate Model 116 2839581.
You have to take off the top of the power nozzel that has the light lense. There are two pressure locks,one on each side. Use a screw driver to release. You will see the screws.Take the two screws out and on some models, there are two pressure locks on the back of the nozzel. Again use the screw driver to release. The top should come right off.Hope this helps.
Posted on Oct 18, 2009
ltldab
  • 152 Answers
SOURCE: the vacuum is a Kenmore Whispertone model 116
CHECK PARTS SITES AS THERE ARE NUMEROUS ONES ONLINE.
Posted on Feb 26, 2010
  • 5370 Answers
SOURCE: On Kenmore Whispertone, model 116
Turn the power nozzle over again, press the handle release and lower the handle to the floor.
Then flip the switch cover upwards and remove the switch.Click this link below to get complete instructions and diagrams:---
http://technoanswers.blogspot.com/2011/06/how-to-remove-switch-from-handel-on.html -------------- this should help.thanks.Helpmech.
Posted on Jun 12, 2011
Manual for kenmore whispertone 300
Which specific model in the WhisperTone line do you have? The manual may be available from Sears Parts Direct. Start here: http://www.searspartsdirect.com/partsdirect/user-manuals .
The manual for the Kenmore 116.27512790 canister vacuum is available here: http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0807641.pdf . This may be useful if the vacuum is similar to yours.
I hope this helps.
Dec 21, 2014 | Kenmore Vacuums
The power head of my 1165581590C Kenmore Power mate Whispertone 12 amp vacuum won't open. It is an older model and it desparately needs a clean!
I am not 100% sure of the model number but most of their powerheads come apart quite easily if you know how. There is a light lens cover on the top of your powerhead. On each side of this cover there is a little clip that holds it in place. You can usually see that spot by simply taking your thumb and pushing the light cover to one side or the other. Place a small flat head screwdriver in that slot and gently pry upward.
Once that cover is off, you will see two screws. Remove those two screws. Now simply grab each side of the cover towards the bottom and back of the nozzle and pull out. This should release it from the base. It will lift from forward from back to front..
Reassembly is pretty easy. Just reverse the instructions.
Let me know if this helps.
Dec 30, 2012 | Vacuums
see this next web and proceed according:
http://www.ehow.com/how_4761328_change-belt-vacuum-cleaner.html
God bless you
May 09, 2012 | Kenmore Vacuums
Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore whispertone 100 model 116. powerhead no
  • The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
    The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw
Jul 18, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
Belt keeps breaking.
your brush roller isn't turning unplug the vacuum and see if you can turn the brush roller and also notice if it turns freely or is it stiff,take the roller out and remove strings,carpet strands and hair.if you can pull the ends off clean the ends good and maybe add just a little drop of machine oil on the bearing on the inside the roller where the bearings are.clean the motor shaft.there is probably old burnt rubber on the motor shaft.you can use a pice of emery cloth ,clean it till you see the polished finish .but i would say your problem is in the brush roller and the motor shaft.i hope i was some help to you.can you please leave some feedback
May 03, 2009 | Kenmore Whispertone 29512 Vacuum
How do I open my Kenmore Whispertone 12.0 to get to the cord reel
The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw. Good luck. - Gary
Mar 30, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Power head for Kenmore Canister Vac
Another potential problem for the increase in difficulty in turning the beater bar (drum) could stem from extremely dirty bearings, located at each end of the beater bar. I've seen hair knotted up to the point it chokes the bar and significantly reduces its ability tpo turn.
Mar 11, 2009 | Kenmore Whispertone 29512 Vacuum
The shaft on the motor for rotating the brush is not moving. It is a Kenmore Whispertone 12 VModel 116 3521290. I am suspicious of the Belt Protection system.
Go Ahead. Use Us.
Jun 10, 2008 | Vacuums
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
251 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
