Question about Ariens Garden
Will not start
I have ariens 1332le snow blower, the engine turns but it will not fire.
i bought this unit Jan 2008.
please help
    Sergeant:
  • 417 Answers
Actually, first you always check to see if there is adequate good condition oil. Then gas, then crank it a few seconds and pull the plug I see if its wet from fuel. If so, disconnect the ground wire from the coil(s) and try to start it. If it starts then try and find where the wires are grounding
Posted on Nov 21, 2013
Did you check the fuel shut-off valve if it is open
Posted on Jan 23, 2009
    Scholar:
  • 76 Answers
First you will have to check for spark, if you dont have a spark tester you can check by taking the spark plug out then connect it to the spark plug wire, hold the spark plug to the engine block while you turn the engine over, watch for spark at the bottom of the plug if there is no spark than you will have to check all wire connections it mabe possible there is a bad ground some where. So lets start there and we will go from there.
Posted on Dec 27, 2008
I have an arien 8524 snow blower. Is there an air filter on this snow blower as my snow blower will not stay running it only starts and runs for about 20 seconds
Most snow blowers do not have air filters. They tend to clog on these units. Sounds like your issues are fuel related. You may try to flush the system with a product called "Start" from Wal-Mart. You will need to follow the instructions on the bottle and try to keep the unit running long enough to run this cleaner through the system.
Feb 13, 2017 | Garden
Have a gravel driveway bought a Ariens 24 Snow Thro adjusted skid shoes to lift machine, is the scraper blade also adjustable, it is throwing a lot of rocks?
Yes, they are all adjustable. Loosen the hardware, Find something to use as a shim... a few paint can stirrers.. put them under the Scraper to lift it about 3/8" then tighten the hardware. See how that helps the stone throwing. Gravel driveways are tough for Blowers and Plows...It's best to actually leave snow on the driveway to pack down and form a Base. Then the next snow will be stone free.
Jan 07, 2017 | Garden
Why my engine doesn't shut off?
You may have high carbon buildup in your piston/cylinder. The engine may fire via a DIESEL ignition. That is, as the fuel compresses in the compression stroke, it ignites just from the residual heat in the hot carbon in the combustion chamber (like an old 1970s car). Try a higher octane fuel (up to 92 or 93). Higher octane resists combustion until the soarkplug fires.
Aug 15, 2014 | Ariens 920013 - Snow Blower, 120V, 22in
How do you put it in neutral
Does it have steering control triggers to turn it left or right...if so hold both at the same time with engine off and see if you can push it..Let me know if that works. Or let me know what kind of controls you have
May 13, 2014 | Rotary Snow Blower Parts Replaces Ariens...
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
Ariens 30 deluxe platinum series won't start
Is this your first attempt of the season to run it? Did you totally drain and run the machine out of gas last year?
10% Ethanol gas left in a carburetor for months is a killer
Jan 03, 2014 | Ariens Snow Blower 921013 ST30LE 305cc 30"...
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
I have a ariens 24 "sno tech it will not throw
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belt closest to the blower assembly. This is the blower drive belt. (Your operators manual will show you the location and how to remove the cover if you are unfamiliar with your snow blower)
With the engine not running, have someone depress the drive lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt)
You can get parts (the new belt) through your local Ariens dealer or jackssmallengines.com
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Ariens 34 In. Zoom Series Riding Mower
I have a Arien's ST724 7hp snow blower and I like to install a electric start , but I do not the model to buy the starter for my snow blower , please can you help me and how to install too .thank you . ...
Jorge, You most likley have a Techuseh 7 0r 8 hp engine. The big problem is that it does not have a stator under the flywheel to allow you to charge the battery or run lights. So the cheapest way for you to add electric start is to buy a 120 volt strter that will just bolt on. You will have to use an extension cord to use it though. You can get the starter from any small engine shop. You just need the engine numbers when you are asking for prices and availablity. The instructions are easy to follow.
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 10, 2010 | Ariens Garden
Garden Logo
332 people viewed this question
Top Ariens Garden Experts
enb54
Level 1 Expert
Mike
Superior Maintenance
Are you an Ariens Garden Expert? Answer questions, earn points and help others
