Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Auto Adjustment keeps turning on every few seconds
I have an HP w2207 LCD monitor. Just recently, auto adjustment started turning on at random times, every few seconds. When it turns on, the screen goes black. Does anyone know how to fix it?
  • Anonymous Apr 11, 2009
Hi, I have a HP VS17E Monitor and it does that too only on any window, boot screens, cd boot setups, windows environment, ext. Anyway I was able to fix my problem at least in the windows environment by simply download HP MY DISPLAY software but it only worked if I had every program set to my monitors highest resolution. If I changed that the autoadjust will change it automatically and cut some of the screen off.
Posted on Feb 28, 2009
I have had the same problem and now suspect that cleaning fluid from when I cleaned the screen may have seeped in. After a number of things I did over a period of 2 weeks the problem went away completely.
1. You may be able, if that is your problem, solve it quicker with a hair dryer at a distance (no melt down!)
2. Run HP diagnostics and clean the registry
3. Re- install drivers
Like I said I think 1 is the most likely. I went from every couple of seconds to completely solved.
Another possibility is that an MS update may have caused the problem and then another solved it.
Posted on Jan 11, 2009
  • 126 Answers
Manufacturer fault. Just buy a new one, honeslty not worth the time of day as you have to get very tekkit torepair this one
Posted on Dec 25, 2008
Auto adjustment in progress keeps popping up
Try turning down the brightness on the monitor, sometimes this will fix the issue, if not the problem is in the inverter board and needs a professional to assess it further.
Mar 10, 2012 | HP w1907 LCD Monitor
Auto Adjusting in progress keeps popping up?
Might be a loose connection, a bad cable, or a bad video card. I'd try the monitor on a different computer--even a laptop. Should give you an answer as to what's wrong. With the laptop, reboot it with the video cable attached.
Jun 18, 2010 | HP w2207 Monitor
My monitor keeps saying auto adjustment in progress
Hello Friend,
This is automatically adjusting your Screen.Horizontal/vertical manual manual adjustment and Focus adjustment can Solve the Problem.Turn off auto feature. I hope your Problem can be Solved by going to this link for Detailed Instruction of your Monitor...
Thanks for Contacting FixYa...Keep Using..
May 11, 2010 | HP w2207 Monitor
Auto adjust in progress keeps flashing every 10 to 15 seconds , I have a HP w2207
my Aser 17" monitor model AL1706 i have some provlem my uper level one line
Nov 07, 2009 | HP f1905 19" Flat Panel LCD Monitor
Auto adjustment in progress popping up and
Right click on your desktop, go to properties, and navigate to the settings tab. There, try to set the monitors resolution to the largest available. That should fix your problem. If it doesn't just try some other resolutions until ou find one that works. I hope this helps, Yannick.
Jun 09, 2009 | HP w1907 LCD Monitor
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
Auto adjustment comes on every 5 seconds
Sometimes that can be caused by a loose or bad video cable causing the monitor to re-adjust for the video signal. You could try resetting the monitor by unplugging it for a few hours and re-plugging it again too. Also check with HP and see if they have any warranty, extended warranty, repair notice, free repair/ replacement.
Jun 21, 2008 | HP f1905 19" Flat Panel LCD Monitor
Samsung 731N Auto Adjustment
Hold menu button for 5-6 sec.
Enable od disable this funnction.
Nov 18, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
637 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
