Question about GigaFast Ethernet EE110-AXP (EE110AXP) Network Adapter
Card does not acquire ip address. repair does not work defaults to 169.254.244.38
  • Robert Lanzone Apr 16, 2007
    connecting through linksys router. other devices are acquiring ips fine. tried switching speed from auto to 100 and 10. still no luck. tried re-installing drivers for card as well
  • Anonymous Jan 16, 2009
    i have a problem my nic card doesnot acquire ip address any ip address and i cant repair
    Scholar:
  • 113 Answers
What is the network adapter connected to - a modem or a router? Is there any other computer or device that is connected to that modem or router and is able to acquire an ip address? This would generally happen when the network adapter is not able to automatically negotiate with the connected device (which might have 10/100 ethernet ports). You can resolve this by forcing the network adapter speed to, for instance, 100 mbps. Please revert back with further observations.
Posted on Apr 16, 2007
  • Sandeep Bakshi
    Sandeep Bakshi Apr 16, 2007
    You may try forcing the card speed to 10 mbps half duplex, however, just to tell you that linksys routers have issues working with gigabit network adapters.
XP laptop will not acquire network address after restarting. It works right after running the setup disk but will not work after a restart. Motorola-6FF0D modem/router connected to Windows 7 desktop. Have...
Pls try this following below and just cool down and read through,
Physical causes and What to Do...
  • Network card could be faulty or malfunctioning, or the port on the card itself. Make sure lights show on the card and if they don't, replace with another one that works.
  • Check that your router or the server is turned on so that the laptop can acquire a valid IP address.
  • Double check to make sure the wireless card on the laptop is turned on. Do not assume it is on by default, do it yourself.
Logical or Software causes and solutions
Many of us are online buyers. Items sold on the internet, especially used items, are not in their default settings. Previous owners do not always reset them before sale, and this causes a lot of issues and unwanted beheaviours. Below are some of the common settings found on Routers:
  • ISP user name and password. If you want to connect to the internet check with your ISP to get your own User name and password, if not ignore this step.
  • Looking at the security options, make sure:
    • MAC address Filtering is not enable. If it is, remove all the MAC addresses on the MAC address table, and enter your Laptop's network card MAC address. With MAC Filtering On, do not forget to enter the MAC addresses of all you wireless devices on to its table.
    • Wireless key settings. Disable the wireless key settings and configure it to meet your requirements.
  • A Laptop to Laptop connection, please make sure the wireless settings on both laptops are the same.
  • Inconsistent wireless Keys. The key on the laptop has to match the one configured on the router.
  • Drivers out of date, update your wireless adapter drivers or your router firmware by checking the manufacturer web site.
  • Wireless not enable on the router. If wireless is not enable on the router, there is no Wi-Fi signal at all. some Router would have wireless turned off by default, and it is the administrator decision to use it or not.
  • DHCP Server misconfiguration. Make sure the DHCP (Dynamic Hosts Configuration) server is properly configured:
    • Enough IP address lease for your network devices
    • The server itself is not down
  • Some simple troubleshooting methods are:
    • Repair the connection. On Windows, click start - Control panel and then Network connections; chose the right connection icon, right then select repair. Windows will, temporarily, disable and re-enable your network adapter to attempt a connection.
    • Reset the IP stack. Click start then Run. At the command prompt type "command" or cmd for short, you are then presented with the command prompt window. Type "netsh int ip reset resetlog", and then restart your Laptop. This applies to desktop computers as well.
    • Reset the router to its factory default. Most routers we use at home are fitted with a reset button, by pressing and hold it for few seconds will bring the router to its factory default. This method solves a lot of the issues mentioned earlier, in one go.
    Nov 10, 2010 | Arris SURFboard SBG900 Wireless Router...
    My friends has a netgear wgr 614 v9, and it wont connect,, juts keeps saying acquiring network address, i tried to reset it ( lil hole at the rear ) but no joy,, how can i solve this,, would someone...
    your computer is not getting IP address from the router. You said that you reset the router. Press the Reset button on the router and hold it down for 30 seconds. release it. Unplug the power to the router and plug it back in. restart your computer and check if that connects. If that doesn't work then assign a static IP address in the range of your router. you will need to find out the default IP address of the router. you will find the default IP address of the router in the router manual or if you go to the web site of the manufacturer, you will get the IP address of that router. Now once you assign a static IP address to the computer it will show you connected , now try to set up your router.
    Click Here for more information about the router and network
    Feb 16, 2010 | NetGear WGR614 Wireless Router
    One of five PCs not connecting to Belkin 54G router
    I would connect it to the router using a lan cable to verify that it will get a IP address and connect to the internet. Write down the IP information and make a static wireless connection with that info. It should work hardwired and wirelessly with this info. If it doesn't work wirelessly you may have a bad wireless card or you may find that their is already conflicting static IP info in the connection that has to be removed. Make sure that on your internet protocol (TCP/IP) properties that you have selected "Obtain an IP address automatically" and Obtain DNS server address automatically". Clear any settings that you may see there.
    Jun 22, 2009 | Toshiba Satellite Pro 6100 Notebook
    Wireless printer gets ip address different from my routers ip add
    Check on the wireless network the printer is connecting to. Make sure it is your router.
    Feb 03, 2009 | Lexmark X4650 InkJet Printer
    Acquiring Address Problem
    you will need to make sure that DHCP is enabled within the routers settings as this will tell the router to assign ip addresses automatically, then go to network connections, right click on your network card>properties>TCP/IP line>properties and tick 'obtain an ip address automatically', click ok, close window and restart pc.
    Sep 24, 2008 | HP PAVILION A6230N DESKTOP PC
    Linksys can't find ip address
    TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
    For XP, Start, Run, CMD to open a command prompt.
    For Vista, Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
    Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
    Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
    Reboot the machine.
    Aug 13, 2008 | Linksys Wireless-G WRT54G Router
    Tiscali wirless connection issue
    Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
    You can however just use a static ip address.
    First of all find out the network address in use.
    eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
    to find out, - start menu - run - cmd - ok - ipconfig
    1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
    Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
    IP Address 192.168.0.2
    Subnet mask 255.255.255.0
    Default gateway 192.168.0.1
    Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
    2wire 1800hg random no internet/random access, repair/wait fixes
    It seems that you said your computer gets the ip address from your router,, which means thru DHCP of the router but if you look at the DHCP settings of your wireless card inside your computer ---the DHCP is OFF -- check your ipconfig/all command as shown in your problem too,,, your wless card does not accept the new IP which comes from your router --as DHCP is OFF on your wless card and sticks with the old ip address whereas the router maintains a new ip for your computer in its table and a mismatch occurs and you loose the internet connection ,,,,thats why repair works and then again the IP changes in the router for your computer and your computer's wless card lags behind and use the old ip adress ..... DHCP--- IS DYNAMIC , WHICH MEANS IT RENEWS THE IP address after some time and you computer gets stuck to the old one ,,, hence mismatch. "you make the DHCP -ON on your wless card too. it will be fine."
    Mar 06, 2008 | 2wire 1800HG Router (RG1800HG00)
    Cannot connect to the internet via the Wireless router.
    contact ur service priovider they will provide u  ur ip address and default gateway as well as dns server address
    After getting ur ip
    go to network connection > wireless network connection > properties > scroll down for internet protocol  and double click on it > click on use  the following ip and then enter the ip address and default gateway with dsn server provided  by ur service provider > click ok
    now u  r done and u can connect 2 the wireless network
    Mar 01, 2008 | D-Link DSL-G604T Wireless Router
    Failure to acquire IP address
    How is the DHCP setting of the modem configured?
    Nov 03, 2007 | Dell Dimension 4700 PC Desktop
    GigaFast Ethernet EE110-AXP (EE110AXP) Network Adapter Logo
    1,665 people viewed this question
    Top GigaFast Ethernet Computers & Internet Experts
    Prashant M
    Prashant M
    WelderArc
    Are you a GigaFast Ethernet Computer and Internet Expert? Answer questions, earn points and help others
