Question about Estate TEDS840JQ Electric Dryer
I have a estate electric dryer with no heat.
The drum goes around but no heat.
    Genius:
  • 2,920 Answers
Check the heater coil and limit switches....if either are bad you wont get any heat
Posted on Dec 25, 2008
Wont dry clothes
Posted on Jan 29, 2009
My dryer has heat but does not dry
is the drum turning? if not you must replace the strap that turns the drum. if it is heating and the drum is not turning , that could cause a fire.
Sep 30, 2014 | Estate by Whirlpool EED4100XQ Estate...
Dryer drum rotates but there is no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 18, 2011 | Estate TEDX640JQ Electric Dryer
What is this feature-"Wringle Prevent"
What the wrikle prevent does is after cycle is done if you dont go take clothing out right away is will tumble the drum without heat for 30 seconds every 10 minutes till the door is opened so the clothing doesnt sit there and wrinkle but gets tossed around lightly so wrinkles dont set in.
Gene
Aug 08, 2011 | Estate TEDS840JQ Electric Dryer
Drum goes around but no heat clothes do not get
heatman101
Jun 16, 2011 | Maytag MED5600TQ Electric Dryer
Dryer turns on, drum rotates, clicks like it did to let gas start but does not ignite. Gas line is functioning. Does not get hot. LPG conversion kit used
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 21, 2010 | Estate TGDS840JQ Gas Dryer
How do you know if dryer thermostate is bad on estate electric dryer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out the electric dryer no heat tip...
heatman101
Sep 06, 2010 | Estate TEDX640JQ Electric Dryer
Air blows drum turns but no heat in dryer
Hi,<br /> If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.<br /> <br /> Check out this tip that will give more details&hellip;<br /> <br /> Gas dryer not working gas dryer not heating<br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><a href="http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not" target="_blank">http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not</a></span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat. <br /> Check out this tip to see the things that can fail to cause your electric dryer not to work.<br /> <br /> Dryer Troubleshooting Electric dryer wont heat<br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><a href="http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won" target="_blank">http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won</a></span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">heatman101</span>
Aug 26, 2010 | Estate TEDX640JQ Electric Dryer
I have and electric estate dryer. The drum is turning but the clothes are't getting dried in the automatic cycle or timed cycle
heatman101
Aug 14, 2010 | Estate TGDS840JQ Gas Dryer
Belt on my Whirlpool dryer, Model # LG5201XTWO is broken.
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Estate TEDS840JQ Electric Dryer
Drum will not turn
YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
RODNEY
May 15, 2009 | Estate TEDS740JQ Electric Dryer
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
See all Estate TEDS840JQ Electric Dryer Questions
Estate TEDS840JQ Electric Dryer Logo
196 people viewed this question
Top Estate Dryers Experts
Tim Whalen
Mike
John Tripp
John Tripp
Are you an Estate Dryer Expert? Answer questions, earn points and help others
