Question about Hoover Vacuums
S3755 Hoover canister bagless vac no power to head
Replaced the power head drive belt which was relaxed and slipping. After replacement turned on vac and power head motor would not run. Removed belt. Motor still wouldn't run. Thought maybe thermal breaker tripped so unplugged for 1/2 hr. Still won't run. Removed lamp and checked voltage at lamp pins--no voltage. Breaker bad? Where is the thermal breaker? Also is it normal to see open circuit 115 VAC at the receptacle in the speed control handle when the carpet button is pushed? Can't check it under load. Damn them for not putting a manually resettable breaker in the power head. How stupid! Thanks!
  • l_boneal Dec 29, 2008
    Doubt if its the breaker...more likely it's a break in the cord connector(s) at either end of the wand between the handle and the power head. My guess is the connector at the bottom of the wand since that's the one that's pulled in and out all the time to change from power head to flooring head. Check the male pins in the mating connectors. If they're tight, it's likely a broken or intermittent wire that connects to one of the female pins in the wand connector. In one of their finer "gotcha" designs, you'll have to replace the whole wand, about $85! If you're good at repair, you can drill out the rivet in the recepacle band, pull out the plastic recepacle, split it apart and solder the broken wire. Drill and tap the wand for a no. 10 x 3/8" screw & reassemble being sure to use a no. 10 star washer. I've done it just because I was so p-----d at Hoover for using such acheap crimp connector in the recepatcle.
Removing beater bar from Hoover canister vac sweeper head
click here > http://hoover.com/file/402/ for the manual it will give you full instruction on belt change on page 7
Jan 08, 2013 | Hoover S3765-040 WindTunnel Bagless...
Power head won't work when brushes turned off
The power head motor's only purpose is to operate the brush, so that's normal.
Nov 29, 2010 | Hoover S3755 WindTunnel Bagless Canister...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
Power head with brush not working
The parts are available for this model but rather than throw money at it by buying parts that you may not need, take it to your local vac shop and let them assist you. It will probably save you some money and time.
Jun 05, 2017 | Hoover S3755 WindTunnel Bagless Canister...
Wiring diagram s3755 hoover
Today I shortened my hose by 4" to get around a tear problem. You can use an Ohm meter to find the right 4 wires. When looking from the top of the canister with the hose heading to your left, the wires should be:
White (furthest connector away from you)
Black - to the switch
Red
Blue
With the Red and Blue going to the speed con trol curcuit board.
Aug 05, 2009 | Hoover S3755 WindTunnel Bagless Canister...
The belt keeps on slipping off causing the brushes to stop
Over time the belt stretches and gets to big to stay put all of the time. Get a new Hoover belt and install it. That will solve your problem
Jun 16, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Hoover Model S3755 Parts List Needed
Go to hoover.com and look up a local Hoover store. Give the a call and ask the to mail of fax you a schematic. They should be pretty helpful.
Jan 07, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Powerhead woes
You should not use this powerhead on any natural or oriental fibre carpet. If you check the brush roller, you will see that the bristle extends out the bottom of the powerhead quite far and that the bristle is very stiff. This is o.k. for synthetic carpets, but will be too aggressive on natural carpet. It will pull material out of the carpet and eventually thin it out. You should use a passive air turbo or a carpet tool for this rug.
As far as the belt is concerned, if it is over a year old, it is due to be replaced. Old belts are stretched and will come off because they are worn out. You might also check to make sure the motor is in place correctly. It is very common that when people want to check the inside of the powerhead, they commonly remove the three screws that secure the motor, thinking that these screws will open the powerhead. If you observe the area between the screws, you will notice that there is a "no screwdriver" warning there. The four screws for the hood are recessed and not as obvious as the motor screws, so this mistake happens quite a bit.
Jan 01, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
