Question about Toshiba SD-1200 DVD Player
Sd-1200 freezes up
Player works great for 20 to 30 min. then freezes as if pause was pushed. can not restart and will not reload disc. must turn off for an hour or longer then it will work for for another 20 to 30 min.
Should I just replace unit or what?
  • 126 Answers
Jsut replace it. Im sure your time is more important than this ****.
Posted on Dec 25, 2008
Hi Need to change NAD T515 to region free/ Thanks
Same procedure as NAD T514
1. Turn player on without any disc in.
2. Push "pause".
3. Push "3, 1, 4, 1, 5, 9".
4. A blue menu comes visible. Follow instructions there, or turn "0" and "pause".
5. Turn of player.
Mar 04, 2011 | NAD T 515 DVD Player
The screen froze and keypad just wouldn't work. How to restore it?
1 Turn off your player.
2 Press and hold the Play/Pause.Continue to hold the Play/Pause button until you perform Steps 3 and 4.If you accidentally release the button, start the procedure again.
3 Gently push the end of a thin object (like a pin or straightened paperclip) into the Reset hole. The reset button for the ZEN Mozaic is located on the left side of the player, with the menu buttons facing you.
4 Slide the On/Off/Lock switch towards the power button and hold until the display lights up. The Recovery Mode screen appears, and four menu items are shown: Clean Up, Format All, Reload Firmware and Reboot.
From here you should be able to choose to reload the firmware.
Mar 02, 2011 | Creative Labs Creative Technology Zen MP3...
My Element mp3 player wont turn on
When your player freezes, it will only start up and not play the songs or even the buttons won't respond to your pressing them, it is more like your computer hanging and never coming back to working fine unless you restart it. The first thing you should try to do is read the instruction manual and check where the reset button in your MP3 player is. Take a small pin and push the reset button. This will make you player go off for and then you can put it on again and it will work fine. However, there is a possibility of data loss when you reset. Most of your stored stuff will be gone after reset. Another thing that you can do to retrieve your player is doing a firmware update. Do a refresh of your firmware and see if it works, in most cases, it does. Other options are the same that you and everyone else will try as soon as you MP3 player freeze. That is opening the MO3 player and taking out the battery. Set the battery back and push the power button again. It is always a good idea to do a firmware upgrade right after .you can also open it up and blow on it.
Sep 30, 2009 | Audio Players & Recorders
Need the code to unlock regions on LG V9120W
1)turn on power
2)draw tray open
3)push 0 button 3 times
4)press 0 (region code)
5)press pause
OR
1. Turn Player on with no disc inside
2. Set the Unit to DVD mode (Not VHS)
3. Turn Player OFF
4. Turn Player on with no disc inside
5. Press pause on the remote control
6. Then key in 3 1 4 1 5 9
[CODE -- will then be displayed on the player display]
7. Key in desired Region number
[0 for Auto Multi Region, or manually select 1 to 6]
8. Then Press Pause again
9. Turn off player and wait 5 seconds, then back on again.
Sep 13, 2008 | Televison & Video
I want to covert my toshibe sd 120e dvd player into a multiregional dvd player and play usadvds
The hack for the SD 220 works on the SD120e aswell. Itook the following off a website that tells you how to do it.
u need to dload the rar file at http://sd220e.chez.tiscali.fr/ to get your region 2 Toshiba sd220e region free. It works great. This is what you need to do
- Download the rar file at the link provided by Labman
- Unpack it using WinRAR
- Start Nero Burning ROM, click File, click Burn Image..., select the .cue file, click open, disable 'Determine maximum speed' and 'Simulation', at write method select Disc-at-once (this is very important), click write.
- Push setup on the SD220e remote control, select under picture:
PAL/Auto: Auto. Push setup again.
- Open your SD220e disc tray and insert the CD.
- Close the disc tray.
- The disc will be read and recognised as a VCD, you'll see the image on
your television flash and after a short while you will not see any image
at all. Wait about 10 seconds and take out the CD.
- Your player is now region free. Tested it with a region 1 DVD and it
worked great.
Jul 08, 2008 | Toshiba Televison & Video
Tevion player shows BAD DISC,
Since the unit is under warranty, you can't touch anything without voiding the warranty. This problem could be as simple as a dirty lens. Bring the unit in for repair under warranty.
Dan
Mar 19, 2008 | Televison & Video
Toshiba dvd player - SD-1200
Its actually in the troubleshooting manual. Pg 126. Try putting in the disk with the label face up, that might work too,
regards
Jim
Dec 22, 2007 | Toshiba SD-1200 DVD Player
Zen frozen on one screen even after I've restarted it.
hard drive sounds bad. has it been dropped?
try to do a cleanup
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 04, 2007 | Creative Labs ZEN SLEEK MP3 Player
Reset button
push the power/menu button and hold it for 15 to 20 seconds until it shuts off, wait 10 more seconds, and then turn it back on.
Dec 20, 2006 | SanDisk Sansa e250 MP3 Player
Toshiba SD-1200 DVD Player Logo
304 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
