Question about Insignia NS-PDVD8 Portable DVD Player
Spinner problem! My player has been having a prolem loading the DVD. I put it in and it will spin then top spin then stop sometimes it will not play the DVD then other times if I hit the Menu button it will go to the menu then i have to go to scene selection to get the DVD to play. I'm trying to figure out what is wrong with it?? Then also trying to find where to get it repaired in the area. I live in Big Lake, MN
  • 126 Answers
Manufacturers issue. Get in touch with them they will arrange a replacement .
Posted on Dec 25, 2008
I have a digital labs model K715 dvd player. when i put a disc in, it spins, screen say its loading but will spin, stop, spin and stop again. Wont play the disc.
Try doing the following...
Making sure the "line select" has been switched from "in" instead of "out". Once you switch it back to "out", the player should work normally.
Mar 05, 2011 | Insignia NS-PDVD8 Portable DVD Player
DVD Player Not loading Movies
optical sensor is burned out or the spindle is not spinning the disk to read it.
Nov 06, 2009 | Coby DVD-224 DVD Player
Toshiba sd-4990 dvd player will not load a disk
Your toshiba is not spinning that's why it keeps on saying loading. Unplug the dvd Open the device,once open plugin the dvd and put the dvd cleaner in the player. take your finger on the top where the dvd disk is and spin the disk. What happening is that you are cleaning the len. keep spinning until it spin on its own.Put the toshiba top back on and clean again. It should clean on it's on. Now you can play your dvd. Clean your dvd on a regular basic.
Mar 12, 2009 | Televison & Video
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Does not play DVD
You need to open top cover and look inside dvd player cd tray. Does dvd / cd disc spins or having loading problem because grrrrr seems mechanical problem.
Let me know your finding to guide you further.
Thank you.
Oct 25, 2008 | Sony DVP-NS575P DVD Player
Wont play
There is no simple "at home" solution to any of these problems listed. However, Since it tries to play or at-least plays Cd's, then that will indicate that affordable repair is possible. I have already repaired several of the Dual units already. With the 7" Dual screen sets, I had to replace the laser assembly or the spinner motor (not spinning fast enough). With the 8" Dual Screen sets, I found mostly that the laser ribbon was binding up in the movement of the laser and preventing it to move to proper position. These repairs should be done by a qualified technician.
May 17, 2008 | Polaroid 7" Two-Screen Portable DVD Player
Phillips portable player PET724
I had the same problem with my PET724. I tried cleaning the lens, letting the battery run dead, even beating on it but nothing worked. When I was cleaning the lens again with some cleaning agent I accidentally slid the laser head as far away from the center as it would go. When I loaded another disc it has worked fine ever since. I have played at least two dozen discs so far with no problem.
Hope this helps.
Apr 19, 2008 | Philips PET724 Portable DVD Player
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
INSIGNIA IS-PD040922
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Nov 27, 2006 | Insignia IS-PDO40922 Portable DVD Player
Insignia NS-PDVD8 Portable DVD Player Logo
88 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
