Question about Brother HL 2700CN Laser Printer
Prints gibberish (english characters, random mix, printing PDFs of 5 or more pages
  • 741 Answers
You need to ensure you have the correct drivers for your computer. Adobe uses PostScript drivers to print out .pdf files. Some drivers are Printer Control Language (PCL) and do not work well with .pdf.
Posted on Dec 25, 2008
Printer prints random characters
Hi Erica,Try to shut it off, but if you can't, unplug it. Then try canceling it and plug it back in.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Brother Printer Support
Feb 06, 2014 | Brother Office Equipment & Supplies
Cleaning inkjet nozzles
Here's what I found here:
http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
Cleaning the print cartridge nozzles
To improve print quality, you may need to clean the print cartridge nozzles.
Clean the nozzles when:
• Characters are not printing completely.
• White dashes appear in graphics or printed text.
• Print is smudged or too dark.
• Colors on print jobs are faded or they differ from the colors on the
screen.
• Vertical, straight lines are not smooth.
43
You can use the operator panel or the Lexmark X5100 Series Solution
Center to clean the nozzles.
Using the operator panel
1 Load paper in the All-In-One. For help, see page 16.
2 Press Options until Cartridges appears on the display.
3 Press the right arrow until Clean appears on the display.
4 Press Select.
A nozzle page prints forcing ink through the nozzles to clean the
clogged nozzles.
5 Print your document again to verify your print quality has improved.
6 To further improve print quality, try wiping the print cartridge nozzles
and contacts (see page 44), and then print your document again.
7 If print quality has not improved, try cleaning the print cartridge
nozzles up to two more times.
Using the Lexmark X5100 Series Solution Center
1 Load plain paper in the All-In-One. For help, see page 16.
2 Click Start Programs Lexmark X5100 Series Lexmark X5100
Series Solution Center.
3 Click the Maintenance tab.
4 From the Maintenance tab, click Clean to fix horizontal streaks.
5 Click Print.
clogged nozzles.
6 Print your document again to verify your print quality has improved.
44
7 To further improve print quality, try wiping the print cartridge nozzles
8 If print quality has not improved, try cleaning the print cartridge
Wiping the print cartridge nozzles and contacts
If the print quality does not improve after cleaning the print cartridge
nozzles, dried ink may be on the nozzles or contacts. To wipe the print
cartridge nozzles and contacts:
1 Remove the print cartridges. For help, see page 38.
2 Dampen a clean, lint-free cloth with water.
3 Hold the cloth against the gold nozzle area for about three seconds.
Gently blot and wipe dry in one direction (this prevents the colors in
the color cartridge from mixing).
4 Hold a clean, damp section of cloth against the contacts for about
three seconds. Gently blot and wipe dry in one direction.
Nozzles
Contacts
45
5 Let the nozzles and contacts dry completely.
6 Reinstall the print cartridges, and then print your document again.
7 If the print quality has not improved, try cleaning the print cartridge
8 If print quality is still unsatisfactory, replace your print cartridges. For
help, see page 38.
Jun 29, 2011 | Lexmark X5150 All-In-One InkJet Printer
Printing random characters
Hi there
This I think is the driver, best to remove the printer driver off the PC close down, and restart again then reinstall the printer driver back to your pc.
All the best Pineworks
May 07, 2010 | HP DeskJet 880c InkJet Printer
HP Laserjet 1200 prints garbage when printing pdfs
it may be you have a virus in your computer
Mar 25, 2010 | HP LaserJet 1200 Printer
It prints gibberish before the print job.
I have had this happen before, this could be you need to change the drum kit on the printer itself, check the indicator light.
Jul 28, 2009 | Dell 1720dn Laser Printer
My netwroked Brother 2700CN prints gibberish pdfs that I download from a partiular webpage. It will print other pdfs. Also, it will print everything if I use a different computer to send it over.
After you click "print", click "advanced" in the bottom left of the print window. THen check the box "Print as image". Hopefully that will do the trick.
Jun 25, 2009 | Brother HL 2700CN Laser Printer
Ricoh CL3500N - not printing all characters on the page
It might be a print driver problem. I think there several different drivers. Go to Ricoh-usa.com and download all the drivers for the operating system you are using and try them. If there is a rpcs driver that might be your best bet.
Apr 24, 2009 | Ricoh Aficio CL3500N Laser Printer
Prints pages with no words but symbols
Print test page from the printer. This prints fine? Then anytime a printer prints gibberish versus what you were trying to print from the computer means you should try one of two things. Download the most recent drivers from the products support site, install these. Be sure to uninstall the old drivers first. Another item that can cause gibberish print is a bad cable. Swapping out with a known good could solve the whole problem.
Print test page from the printer. This does not print fine? Then you are looking at something wrong with the printer. The cable and drivers would not be the cause because the only piece of equipment involved at this point is the printer. First step I would try in solving this. Download and update the firmware from the support site. If this does not work, then you may have a defunct printer. If you are under warranty, contact Dell tech support.
Mar 12, 2009 | Dell 1600n All-In-One Laser Printer
Printing gibberish
gibberish printing is normally a sign of outdated print drivers. Try going to HP's support site and download the latest PCL driver.
Sep 22, 2008 | HP LaserJet 4100 Printer
Brother HL 2700CN Laser Printer Logo
500 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
