Question about Western Digital WDG1C2500N MyBook Premium 250GB External FireWire USB Harddrive Hard Drive
WD My Book 250G no longer recognized by 2 diff PCs, making noise
I took my My Book to my parents' house to "share" music with my father, left the drive hooked up with the computer on overnight, but didn't transfer any files. The next day his computer couldn't find the drive, and found the same problem here. When I plugged it in, the booting up noise sounded louder, and repeated multiple times - then noticed the side was dented (transported it in its original packaging, but I don't know if it got knocked over elsewhere). I really want the files stored on it (photos, music without copies elsewhere), so what should I do? Here's the options I've come up with so far...
1. I have tech-savvy friends who offered to take a look for free, but I don't know if this is a good idea (likelihood of losing stored files).
2. I called Disk Doctors and they said it sounds like a physical problem, which they'll try to fix for minimum $500 in their clean room.
Any advice beyond 1 and 2? Is Option 1 reasonable and safe to start with? Thanks in advance.
  • pweel1 Jan 05, 2009
    I tried what you suggested, but the drive didn't show up under the disk management, and I could only change the drive letter of the C: drive, which was not recommended. I tried refresh as well - no luck. Thanks for thinking of me and my poor broken drive.
This sounds like a similar case. A guy I use to work with had a WD he was in his truck heading home with it sitting on the seat beside him. He hit the brakes and the HD was thrown from the seat to the floor. He then tried to hook it up to see if it was broke and could not get it to work on any computer at work. It was a cubicle job so there were plenty of computers to work with on this. Somebody suggested to change the name of the drive. He then went to the help menu on his computer asked how to change the drive letter. Once he did that it worked fine. What happened was somehow the drive letter got changed to a letter that the computers used commonly so with a drive letter being the same the computer will not detect that there are two drives. Changing the letter to a different letter will allow the computer to recognize the drive which will enable the hard drive to function.
Posted on Jan 05, 2009
"the parameter is not correct" msg re WD My Book, unable to access
Try plugging it into a different computer to see what it does. Sometimes a computer's operating system will recognize an external drive differently if it has only a slight problem, whereas another computer's configuration may treat the problem differently. Some external hardrive software can get jumbled by the programs of a computer or sometimes even their own software programs can cause slight problems. It sounds like a software problem with bugs that can be ironed out. Also some computers will change the drive name to fit into the order of drives it recognizes. Good luck!
Jun 01, 2013 | Western Digital WD My Book Essential...
I'm connecting 2 PCs to 1 printer .... using "Manual Share Switch #MT-1A2B-C" device. It seems an extremely uncomplicated connection to me. However, neither of the computers recognize a...
Hello.
Try connecting one of the PCs to the switch to see if it prints. If still no printing, then the share switch is probably faulty.
Hope this helps.
Jan 13, 2011 | Computers & Internet
I removed the 4wd actuator on my 1997 1500 gmc located on the front differential and pressed the 4wd hi button in the cab. The actuator traveled out. I then pushed the device inside the differential...
4wd actuators are in the transfer case not the diff housing
on a diff housing it is more likely to be a diff lock to lock the 2 front wheels together
Jul 02, 2017 | GMC Sierra 1500 Cars & Trucks
My wd external hardrive is not recognized anymore on my pc. I have tried on other pcs and tried different usb cables and nothing. I do not want to reformat the drive because I have important information...
Hi. If you here some clicking noise then your external hard drive might be busted already.
Try to contact a local tech and see if he can still pull out your data from there.
Hope you'll be able to extract your files back.
Have a great weekend!!!
^_^
Jun 04, 2010 | Western Digital My Book Essential 320GB...
Only showing as a network device on 2 of the 3 pcs on the network
Did u added the new network devices, or did u wait till thy popped up?
If u didn't added them manually, then go to networklocations, add network location, press next, and again next, then type in \\mybookworld\"here the name of the folder of your mybook, ex. Movies or music,.." (without " ")
Do it for every folder.
Oct 07, 2008 | Western Digital 500GB My Book World...
Problem turning on hd
WD = Western Digital , 250Gigabyte external USB drive.
This is where you may need to perform all the USB checks and trouble shooting in the book + load any driver software that came with the drive.
also I would need to know what motherboard and what operating system you are using before I can help farther.
normaly windows 98 and 98 se did was just not able to make proper use of the USB ports , also on nforce2 motherboards service pack2 was required to enable the USB 2.0 feature
we are constantly lied to by the computer industry so get used to it untill the feds crack their skulls.
and remember if it's not hebrew , it's a lie :-> lhime shalom.
Sep 08, 2008 | Western Digital 250GB MyBook External USB...
WD Hard drive no longer works
This is mostly a power issue, but if you use a hub it may be latency as well. Some USB ports limit power to 400-500ma per port, the Passport Essential needs a bit more than 1000ma and won't work at all with these computers. Other USB ports/hubs limit the total power available for all devices combined... this is why, in your case, you can use one drive, but not both.
FYI, higher speed devices also tend to need shorter cables due to latency. (Light & electricity travels about 1 foot, or 30 cm, in a billionth of a second; this limits the size of high speed devices. In layman's terms, latency is the Brontosaurus effect, since the head takes a while to talk to the tail.)
To boost power, Western Digital recommends using a 22" USB 2.0 Power Booster Cable (WDCA029RNN) to combine the power of two USB ports into the one Passport Essential USB port--it is also a bit longer than the original 18 inch cable. For all EXCEPT the black Passport Essential drive, you may also the WD Passport™ Power Supply Adapter (WDPS021 for the US voltage version). See Western Digital knowledge base ID 1296 for more on this issue.
Hope this helps!
Apr 12, 2008 | Western Digital Passport WDXML800UE...
How do you set up multiple WD Anywhere users on the network to share the same MyBook World Edition
hey,
-No WD Anywhere allows 5 users I think.
This could only be the solution, if you installed WD Anywhere on other PCs before
Check out the MioNet site, think they give options for new users.
if this is not the problem, I don't have a solution by now.
bye
Feb 08, 2008 | Western Digital 500GB My Book World...
Western Digital WDG1C2500N MyBook Premium 250GB External FireWire USB Harddrive Hard Drive Logo
101 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
