Question about Sony KV-32V16 TV
Hi, I just inherited a SONY KV32V16 television. My brother brought it to my house to hook up. I have basic cable using a cable line out of the wall. When he hooked the cable to the TV I only get channels up to 26 whereas I should be getting 99 channels and the channels where the stations are appearing are different from what they were on my other television. My brother said I need to get a converter box to get the rest of the this true?
  • berniebear_b Dec 25, 2008
    Thank You, I appreciate it!
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    yes, its true.
    your TV has old technology in tuner thats why cant tune hyperband signals.
  • 10,594 Answers
Any time :)
please rate the info.
Posted on Dec 25, 2008
Westinghouse VR-2188 will not find channels when hooked up to comcast basic cable box but will if connected straight into wall, whats wrong? Cable box works on all other TV's in the house also so it is...
Make sure you have selected "cable" as the source input to the tuner. If there is a selection for both digital and analog channels when doing a channel scan then select it.
Jan 04, 2014 | Westinghouse Televison & Video
T v signal keeps breaking up n losing channels
If cable etc have it looked at--line from it or a sat feed etc--could be a bad connection or a problem at the source if all sets have same issue--if I was for example using a single line coming in--disconnect it and hook it directly to a single set--if problem not there it is in the house--if there it is outside.
Jun 07, 2012 | Sony Televison & Video
I have a Phillips TV and can't get any channels on it all other TVA in house are working fine when I try the auto programming and try to select cable it says indicator is available for diigital b
First thing to do is see if a DVD etc. hooked to a rear input works.
If it does you may have to go into the menu of the set and set it back to regular cable to be able to program it.
If a cable box is used here you could also connect from its rear audio/video jacks (most models have that) to a set on the rear of the TV and bypass the issue altogether.
Apr 03, 2012 | Televison & Video
I got a new computer EMachine. I wanted to hook up my Brother MFC 420 using my CD, but no luck. Maybe I have it hooked up wrong. My last computer had a telephone line hook-up. but new one doesn't. I...
Hello s_fields75. I just read your problem and was wondering if you checked your cable connections. You stated that you may have hooked it up wrong. I would definitely make sure your cable connections, USB, etc., are correct. The printer is an all-in-one and should just automatically find the connection through your modem for the fax feature. If not, you might need to get a splicer for your phone line (you can pick one up at radio shack for less than $10). Unhook your phone line from the wall jack. Plug in the splicer into the wall jack, then plug the phone cable into one jack and your fax phone cable into the other. That should do the trick. If not, you may need to download an updated driver from emachines or brothers' websites. Hope that helps!
Sep 22, 2010 | Brother MFC 420CN All-In-One InkJet...
I just got my first HD TV, I want to know how to use HDMI cables to hook up my suround, ps3, Wii, and Cable.
Very easy to hook up.It just two USB hubs hook up with a wire basicly.Use 3 HDMI cables for one each device.
Feb 16, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a Sony Bravia KDL32S3000 and need a table top stand!
Hi, i have a sony bravia KDL 32S3000 and we want to take it down from the wall but have lost the stand, does anyone know where i can get a new on?
Jun 20, 2009 | Sony Televison & Video
Played ps3 on my brothers hd tv
do u have hd?
if not u need to change ur settings to video instead of hd! but when i had to i needed it hooked up to hd first then went through settings to change it or it will be blank screen!
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
SONY KV32V16...can't get all my cable stations.
I called our cable company about getting a converter box and it ended up I didn't need one after all. The cable rep told me to go to the menu and try the auto-programming. He was familiar with the TV I have and said that a converter box is not necessary. So, I tried the auto-programming and still didn't get all the channels...then I noticed on the menu for the channel set up there was the word "Cable" and after it it said "Off" so, I switched that to "On" and did the auto-programming, and Presto! I got all my channels.
Dec 25, 2008 | Sony KV-32V16 TV
Television lines
This sounds like a bad cap in the power supply. The component is only starting to fail under load and heat. I'll look up your specific model and see if there have been any reports of this type of problem.
May 28, 2008 | Televison & Video
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Televison & Video Logo
79 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
