check if there is a little red button on the back .... that says reset click it,.....if not then go to intenet explorer ... type the ip in the adress bar..... a username / password sign should come on ... for username leave it blank for the password right admin and it should take u to a internet sight ..... go to security settings and reset it ...u will figure it out from there truse me ! hope i helped -el
D-Link DI-704P Router was used only as a switch (DHCP turned off) and worked fine while connected to...
(More)
D-Link DI-704P Router was used only as a switch (DHCP turned off) and worked fine while connected to the LAN via LAN (not WAN) input and provided connection to the (home) network for not wireless PC and Laser Printer (using router's printer port) for a few years. All over a sudden it stopped responding, I can not reset it to the facory settings (followed all published procedures). If this is a known issue please help to resolve. Hellooooooooo experts, need your help. Appreciate .............. Alex.
Hi everyone! I got a problem with my D-Link DSL-604T ADSL modem router. Suddenly, after a climate...
(More)
Hi everyone! I got a problem with my D-Link DSL-604T ADSL modem router. Suddenly, after a climate storm the device enter in a LED flashing light which wasn´t occurring before. This is the second time I got this. That happened wiht other Dlink modem Router before. This one still working with WIRELESS COMMUNICATION, B U T no more wired PCs can access the Internet. The PC says "... Lan cable not connected. Please verify your cables... I powered off the routers many times and for long time period, That still happen. I switched the cables from different RJ45 router ports and I also removed the DLink switch box in the middle I had. Seems that everythink stays the same. Can ANYONE HELP ME PLEASE. Any clues or suggestions what this may be..... Regards LUIS
im trying to view tv from internet but modem is in seperate room i tried to use the d link i think i...
(More)
im trying to view tv from internet but modem is in seperate room i tried to use the d link i think i am not conecting them corectly can you advise
