Tecnik TKL9260 Front Load Washer
Problem for Tecnik TKL9260 Front Load Washer
My washer is very noisy, can i reduce the noise?
By Joey2 - usenet poster
Solution #1
posted on Aug 08, 2005
Somewhat Helpful)
Peter1
Rank: Apprentice
Rating: 0%, 0 votes
Redistribute heavy items or Adjust the feet.
Was this helpful?
Yes
No
Solution #2
posted on Aug 31, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Make a cushioned base to isolate the washer from the structure. Cut the base large enough for the washer and dryer, plus 2 inches on each side. I used an interlocking rubber mat, the kind you can find at the warehouse stores. You can also use a kid?s foam interlocking puzzles that you often find in garage sales. I cut a sheet of ¾ inch A/C plywood for the top. Use at least ½ inch plywood or OSB. Tape or glue a piece between the washer and dryer.
Solution #3
posted on Jul 02, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
possible bearing needs replacing....do it yourself easy job
Popular Solutions for Tecnik TKL9260 Front Load
Questions and Unsolved Problems for Tecnik TKL9260 Front Load
Do you recommend Tecnik TKL9260 Front Load Washer?
Answer
Answer
the cycle completes then drain and spin does the proceeder the drum isnt spinning around.
Answer
i have a tkl9260 with the inner drum not going round the outer one is ok
Answer
Having lost instruction manual can you please tell me which dial to use for a short wash and spin.
Answer
not a front load washer...top load...my old washer seem to not spinn water out...ask repair man he... (More)
Answer
washer wont enter drain and spin cycle...tub is full of water. i took apart console and found the... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Sedona, AZ
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
