Question about Watches
How do you set a Kenneth Cole kc1314 watch?
I can set it forward, but not backwards, and it's six days behind. There is a wheel on the side that seems to do nothing, one button that stops it, and another that sets it forward a minute.
SOURCE: Kenneth Cole KC3754
www.genevawatchgroup.com will come up on google, I got it to come up today, 20 Nov. '07 and clicking on the first heading that came up, "geneva Watch Groiup" I got on and was able to print out a repair service sheet for Kenneth Cole
Posted on Nov 21, 2007
SOURCE: watch bands f/ Kenneth Cole
You can try calling 1-800-874-0907
and here is a link for a KC replacement pdf
http://www.genevawatchgroup.com/pdf/repair_kennethcole.pdf
Posted on Jul 27, 2008
SOURCE: HOW DO I TAKE A LINK OUT OF THE WATCH BAND
Start by looking at the inside of the watchband, there should be a arrow pointing up/down. Take a pin and put it in on the side that shows the arrow going down. Take a hammer and GENTLY tapp the pin. The pin should push out a pin in the band. Do this as many times as you have to for the size you desire, and then put the pin in the same derection as you tapped the pin out. Usually you will also see a **** on the side youn DON'T want to tap out. If you still; have a problem don;'t hesitate to write me, and I will be glad to take you step by step with this. Good Luck!!
Posted on Aug 11, 2008
escapement
  • 2334 Answers
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
  • 5 Answers
SOURCE: How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
Posted on Dec 20, 2008
How do i set time for Kenneth Cole Reaction New York Digital Chronograph Men's Watch # KC1494
How do i set time for Kenneth Cole Reaction New York Digital Chronograph Men's Watch # KC1170
Jan 09, 2015 | Kenneth Cole Watches
How to set day on kenneth cole new yor ks1004? thanx
Click on this link to a manual. They make one manual for all their watches. Kenneth Cole Manual
Aug 25, 2011 | Kenneth Cole Leather #KS1004 Watch for Men
How do o set the time on a Kenneth Cole watch kc1687?
Hi! Welcome to FixYa!
I was able to find a link that details on how to set time on a Kenneth Cole watch. Please on the link: http://www.ehow.com/how_5930839_set-time-kenneth-cole-watch.html
Hope this helps.
Jun 21, 2011 | Kenneth Cole - Ladies Watches - RK4087
I have a Kenneth Cole Reaction KC1433 and don't know how to adjust the day of week ? The stem only appears to control the time of day and the day of month.
Pull out the knob on the side 2 clicks and keep spinning it. it will advance the day if you keep spinning the dial.
Dec 29, 2009 | Kenneth Cole Watches
How to set date in kenneth cole watches kc1345
Good day Sir, The winder has two click points ...
1.pull out to the 1st click point to set the date.
2.Pull out to the 2nd click point to set the time.
have a nice day.
Dec 02, 2009 | Kenneth Cole Reaction KC1345 Watch
How to adjust time, day or alarn on Kenneth Cole KC2516 digital watch
There are 2 buttons on the right side, depress the lower round button twice with a pointed object (like a pen). Only one number should appear (month) advance if desired with the top square button. Depress the round button again (once) to advance to next number and advance, continue this until you complete the settings.....
May 10, 2009 | Kenneth Cole KC2315 watch
Watches Logo
61 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
