Question about Toshiba Satellite A100-S8111TD Notebook
How to change display size to full screen
Disploay is less than screensize in windows XP
  • 741 Answers
First, there is a button on the monitor called the "DeGrauss" button. Push on that to clear your monitor of any defects. Then there is another button that "stretches" your screen on the vertical sides. Play with that button next until it is to your satisfaction.
Posted on Dec 25, 2008
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Reinstalled windows xp, now all text is small, screen is not full size, mant others hace complained about this problem...what gives!!!!!
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
http://download.cnet.com/nVidia-Graphics-Driver-Windows-XP-Media-Center-Edition/3000-2108_4-10044975.html
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size %
click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it
if you do not see these tabs in the top toolbar
right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
there should be some adjustment tabs located on or on the underside of your monitor you will need to find the menu tab first you might see some arrows with pointers to extend or retract your screen and one to locate it centre
hope this helps
Jun 19, 2012 | Sony VAIO PCV-RS310 PC Desktop
I have an AMD athlon processor. I want to set my screen resolution to 1920 x 1080 (Full HD). But in Properties --> Settings, this option is not there. My monitor's native resolution is 1920 x 1080....
click start control panel,display,desktop you can select a different desktop from the drop down list
always click APPLY after making any changes hope this helps
May 24, 2011 | AMD (axmd2400fjq4c) Athlon XP 2400+, 1.8...
Screen suddenly displays less than half of full size. How to expand to full view? Help!
Right click the desktop, properties, change the resolution to the appropriate size. If this does not work try using the menu accessed by the buttons on the monitor to do a auto configure on the correct size of the screen.
Mar 30, 2011 | Dell Computers & Internet
HOW DO I CHANGE THE FONT SIZE. I WANA MAKE IT LARGER.
One way to adjust/set the default size (to get a larger font size) is through your Control Panel - Display - Settings window, where you can select a larger font.
If you are using a browser (e.g. Internet Explorer), there is way to increase (or decrease) the font size (displayed on the screen) using the "magnification" option at the bottom right corner of the screen. Simply click on the "magnifying glass" and increase/decrease the value, e.g. to 150% .
Jan 02, 2011 | Acer Aspire One PC Notebook
Desktop screen saver was not full screensize, so i set to maximum setting 200% and now the whole thing is too big and desktop icons way too big to work with, how can I get into system to reset or...
It sounds like you changed your desktop background resolution settings and not the screensaver. Right-click on your desktop on any clear area that doesnt have an icon and if this is WinXP select properties, or if Vista select personalize. Select the settings tab and you should see a screen resolution adjustment slider that will allow you to change your screen rsolution which intur affects the size of all your icons etc. Select the size that suits you. 1080 X 786 is a good place to start. You're probably set to 800 X 600 right now.
Oct 31, 2010 | Microsoft Windows XP Professional
Game display only occupies the center portion of monitor not full screen. Thinkpad A22m w/ windows xp home SP3. Can't get the game screen to display on the full monitor screen.
It is most likely that the game is unable to operate at the resolution that your screen is set at and is compensating by sizing the game window to the required size. You might change you display resolution to a lower setting.
Hope this helps! Rate my solution!
Jan 07, 2010 | IBM ThinkPad A22m 2628 Notebook
Laptop screne displaying 1/2 orginal size. need to reset pls
Jak, Go to Start->Control Panel->System->Hardware->Device Manager-> Display/Monitor. Select the monitor and uninstall it. The Go to Actions and select Scan foe new Hardware. Windows will automatically detect the hardware and install the driver for it. Save it and reboot into full screen windows.
Oct 26, 2009 | Computers & Internet
I have a dell with windows vista. the monitor is 20 or 21 inches wide screen. I recently had a friend try to install windows xp but at the last attempt he tried to reformat my computer & install it xp...
You can adjust the screen resolution to increase the size of the image to fill the screen.
Go to the Control Panel - Display - Settings and adjust the screen resolution to 1280 X 1200 pixels. If this still doesn't fill the screen then increase it further say 1600 X 1200 pixels even higher if necessary.
Aug 19, 2009 | Dell Computers & Internet
PCG=TR3A
When you formatted the hard disk of the laptop, the appropriate drivers were also erased. It is therefore necessary to reinstall the drivers and specifically for your concern, the VGA Display. Pls click here to view available downloads for the Sony PCG-TR3A. You would be particularly interested with the Intel Graphics Controller Driver.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | Sony PCG-TR3A Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
