Question about Goodman GMS90703BXA Heater
No flame to start
All system is woking exept the ignition for the flame, I'd like to find a solution fo my problem
  • Anonymous Dec 29, 2008
    Hi, I have the same intermittent problem. 1 month old installation, nice new unit.
    - Thermostat calls for heat
    - Blower motor starts
    - Ignitor glows red
    - Gas valve does not come on before the Ignitor quits
    - Furnace tries this 3 times, quits, and then light blinks once
    I can shut down power to furnace, letting it reset I think, and then furnace tries again and usually works fine.
    Suggestions welcomed, thanks
  • jrclark2008 Dec 31, 2008
    gmh95/gch9 new installation,started up normal, ran 15 minutes, now no burner, all prestarts seem normal,ignitor glows then shuts down, seems like no gas to ignite
  • 1,420 Answers
If the ignitor is glowing, we will need to check for 24 volts AC across the gas valve. If you do not have it, look at replacing the ignitor first. Even if it glows, it may not be sending the signal to the control board. Secondly you will need to replace the control board. If you get 24 volts for a few seconds but does not ignite, you either have a bad gas regulator, dirty burners or a bad gas valve. What is abnormal is that you say it runs for 15 minutes but does not restart.
Hope this is some help
Posted on Jan 02, 2009
Repair t 4000
You did not state whether the flame ignites or not. If it doesn't, the check to make sure the gas line to the dryer is not turned off. You should hear the gas valve "click" while the ignite is glowing.
You can "crack" the gas line at the value to make sure gas is going to the valve.
If you have gas at the value, and do not hear the click, then the gas valve is not opening. Either the valve or the controller is not working.
If you are getting a flame but it goes out quickly, then it is possible the flame sensor is bad.
If you do not feel comfortable doing this, call a qualified appliance repairer technic
Apr 21, 2014 | Kenmore Dryers
The glow stick lights up; approx30 seconds later, you can hear and smell the gas turn on, but the flame does not start
Depending on the specific unit you have the hot surface igniter (glow stick) may be only for lighting the pilot, which then ignite the main burners. The flame has to be proved before the gas valve opens for the main burners. This is done by the flame rod, which could be faulty in your case. The proximity of the igniter could also prevent ignition. Check that the flame rod is clean and secure. Note. be very careful when servicing gas appliances, and never ever use lighters, matches or any other flame source to light them except for the ignition system supplied by the appliance. These appliances are designed and built with safety devices to prevent ignition when it senses a fault or malfunction. This is all for safety. Do not bypass safety devices, it can kill. Call a qualified tech.
Dec 07, 2013 | Ruud Heating & Cooling
I have a 2000 heritage softail FLSTC.It was warming up nicely fo 30 seconds. then just started sounding really crappy and stalled. I fired it back up but it started running really rough and died again. I...
Hi Diana, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 13, 2012 | 2000 Harley Davidson FLSTC Heritage...
Bryant model 340mav no flame status 31
try jumping out pressure switch see if it lights , see if flame senser is clean.
Apr 21, 2012 | Heating & Cooling
Went to bed last night with heat woke up today everything house was cold, looked at thermastat it said 63degrees,, checked out furnace it starts up but doesnt ignite, sounds like its in the start up stage...
Does the hot surface igniter glow? If not, it is probably cracked. If this is
a 90% furnace, it could be that yuor intake air is causing the problem.
Dec 27, 2009 | Goodman GMS90703BXA Heater
My goodman heater will not run all of the sensors check out ok and have voltage the vacuum switch is also working I am getting one blink after the furnace shuts back down,there is no voltage to the...
This is a step system for heat ,,, step 1....... thermostat calls fo heat and send power to the vent fan motor, it proves its running by a small suction on the red tube which closes a switch and tell the c. b. to go to step--2 lite the hsi this glows &in20 seconds....step --3 the gas valve opens and dump raw gas in the venturis tubes.. and proves it has a flame thru the flame sensor. and step 4... the box heats up and closes the fan switch..
Dec 20, 2009 | Goodman Heating & Cooling
Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer starts but flame extinguishes after a few seconds
it is clear from your reading symptoms that is asensor thermostat problem
thanks
Jul 11, 2009 | Dryers
IGNITION IS DEAD, CAR WON'T START
Crankshaft position sensor is the most likely problem.
Feb 04, 2009 | 2000 Cadillac Catera
Goodman GMS90703BXA Heater Logo
48 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Dennis Boxerman
vance jones
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
