Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Connect netgear wpn824 to DSL router using usb connection between DSL router and wireless router
  • Carl Navarro
    Carl Navarro May 11, 2010
    Why? That should be some sort of trick. Aren't they both USB "B" connectors?
  • 854 Answers
Call your ISP. Change the DSL modem from USB connect to ethernet connect. There is no possible way two match the two device
Posted on Aug 16, 2009
Trying to connect wpn824 router though dsl with Windows 2000
First make sure that you can access internet through the router when connected to it wired. If yes, then please perform the steps below to configure settings:
1. Open the browser(Internet Explorer or Mozilla Firefox) on a computer connected to the router.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'.
6. Set the 'Authentication Type' as automatic.
7. Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
10. Click on Wireless Settings under Advanced in the left hand side menu.
11.. Click on Setup Access List. Uncheck the option Turn Access Control on and click apply.
Scan for the wireless network on the computer with the wireless adapter and connect to your network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 18, 2009 | NetGear RangeMax WPN824 Wireless Router...
My Netgear WPN824 v2 router is not sending a wireless signal
- Updating the firmware of your router will do to fix the issue.
Mar 16, 2009 | NetGear RangeMax WPN824 Wireless Router...
Need to set up router
Provided you have a broadband internet connection (DSL or Cable), it is easy to install the router. There's a CD that came with the router and you can use that for initial setup. It will guide you through the process of installation.
Jan 11, 2009 | NetGear RangeMax WPN824 Wireless Router...
Netgear range max keeps dropping signal
Is it cable or DSL? Cable should be fine but DSL gets slower everytime a second or third connection is added.
Jan 04, 2009 | NetGear RangeMax WPN824 Wireless Router...
Netgear wireless wpn824
Sounds link you need to setup PPPoE on your router. Not knowing who your ISP is, Netgear has this website that lists a lot of ISPs support on setting PPPoE up. that is located here: Netgear
If you can't find the info there, basically what you need to do is on your router, typically the main page, you might see an area that lists: DHCP, Static, PPPoE (or something similar). What you need to do, is select the PPPoE option and put your ISP login information (that is on your DSL modem now) there should be a connect or login button once your finished. Once that is done, your router does the logging in, instead of the modem.
Feb 03, 2008 | NetGear RangeMax WPN824 Wireless Router...
Neatgear wireless router wpn824 v2
Windows, if that's what you're using, may be connecting to a different router than yours. Verify that you're connecting to your access point.
Also, make sure there is a good connection between the router and your cable or dsl modem.
Finally, you can try connecting your computer to the router using an ethernet cable. That will at least let you verify that the computer and router work together, and you can configure the router and so forth. If connecting with a wire succeeds, that narrows the problem down to the wireless network connection.
Here's the manual. Troubleshooting is near the end, but it doesn't look like your specific problem is listed...
http://kbserver.netgear.com/pdf/wpn824_ref_manual.pdf
Jan 08, 2008 | NetGear RangeMax WPN824 Router
Can not get netgear router to work with dsl internet
I have been able to connect via the wired connection from my desktop, but I am not able to get the wireless to work. My laptop recognizes the wireless network, but it will not connect...go figure! I also have gotten disconnected each time I have called for support today as well.
Dec 26, 2007 | NetGear RangeMax WPN824 Router
Netgear WPN824 wireless router
there is no reason why you shouldnt connect at 108 mpbs, so there are only a coulple of things you can try, the first is to change the channel that your router transmits on within the router settings, although this should automatically be done by the router when it comes up against any interference. Secondly try the adapter in a different usb port as USB 2.0 should be used and the port may not be recognised as a high speed port. Double check the router connection transmition speeds is set at 108 mbps; as it would also be able to transmit at a lower speed of 54 mbps so as to be backward compatable with 54 mbps adapters
Jun 30, 2007 | NetGear RangeMax WPN824 Router
Wpn 824 wireless issues.
if you have set up the wireless connection and enable it in the router, i assume you have disconnected the wired RJ45 cable to the pc, if not do so, as the pc's ip address is still being sent to the wired adapter and needs to be giving the wireless adapter an ip address itself as you cannot have two. Either remove cable or dissable the wired network card and ensure you enabled DHCP in the router settings to automatically give the pc an ip address, ensuring that thw wireless card is also set to obtain an ip address automatically in the TCP/IP properties of the wireless network adapter.
Jun 21, 2007 | NetGear RangeMax WPN824 Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
145 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
