Question about Audio Technica ST90MKII Dynamic Microphone with Clip Microphone
No sound gigaware clip on microphone is not working. It plugs into the pink plug of my dell with a mini-plug. Why doesn't it work? The computer uses soundblaster as it's system. I've tried many adjustments. The speakers are OK otherwise and play normally.
  • Anonymous Feb 20, 2009
    The same 1
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
I need an instruction manual to hook the speakers to my computer
There are no manuals for speakers. Speaker wires are color coded. Computer sound cards are likewise color coded.
the light green sound card mini plug port is where the green speaker wire is plugged in.
Pink is for microphone.
Black and orange sound card ports are for additional speakers.
Jun 28, 2010 | Boston Acoustics BA790 Computer Speakers
How do I plug my BA745 Boston speakers into a MAC desktop with one headphone outlet in the back?
I have the same speakers. It should have two plugs, one green and one pink. the pink plug is for a microphone. On the side of the speaker with the control knobs, you will find a headphone jack and a microphone jack. Unless you plan to plug a microphone into the pink microphone jack on the side of the speaker, you don't need to plug in the pink plug that goes to the PC. This is basically a microphone extension cord that runs through the speaker cord. That's all the pink plug is for. The green plug, on the other hand, is for your audio out. take the green plug and plug it into your computer's head phone outlet and you're good to go. You can use the speakers with any device that has a headphone jack. Just make sure you use the green plug, not the pink plug.
May 03, 2010 | Boston Acoustics BA745 Computer Speakers
Mic wont work of course
which operating system do you use? and check the sound driver from { if windows,right click my computer then click manage then device manager, see there is sound driver is installed or not.} if not then install sound driver.
Apr 29, 2010 | Cyber Acoustics CVL-1064 Consumer...
Gigaware microphone 33-124 no sound with Windows XP SP3
Does it show a message like "unknown device" in winXp? then probably it needs an installer in order for a device to work properly, but if its working in the other computers running winxp then probably your own computer you are using have a problem with the usb ports on it. Hope this could help..
Oct 23, 2009 | Computers & Internet
Computer wont recognize the microphone on the turtle beach x4
Can you try using the X1 mic on your PC? Green plug to green jack, pink plug to pink jack, USB plug to USB port. Talk into the X1 mic. Can you hear your voice? If yes, then you probably have a bad chat-controller cable. If no, then your X1 mic may not be working. If that's the problem, you should contact Turtle Beach tech support for help. support@turtlebeach.com.
Jul 21, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Speakers and controls are working but sound barely comes out.
Check the back of the computer. Typically this caused when the connection is loose or the speakers are plugged in to the wrong jack. The correct jack on a Dell is usually a light green color. The Microphone is pink, etc.
Jul 15, 2009 | Dell A215 Computer Speakers
Microphone input on Dell Inspiron B130 doesn't work
Your jack may have been damaged, or the apple mic may not be compatible. Purchase another pc compatible mic to check. Or you could try a multimedia headset with mic that plugs into your usb port. Take a look at RadioShack for headsets, I saw one in a store near me. and they should have them online.
Jan 27, 2009 | Dell Inspiron B130 Notebook
Speakers won't work
Hi, you may want to try plugging the input line of the Dell speaker to the other jacks. Normally green is for speaker, pink - microphone and blue is for line-in and all are normally at the back of the computer. Sometimes, the back are deactivated if there are jacks in the front., so you may to try plugging it in the front if they are present. Assuming the speakers light/power up, if you want to check if they are working is by touching with your finder the input plug which should produce a humming sound. Also worth to check the drivers of your sound card. Hope this works for you. Regards.
Apr 14, 2007 | Dell A525 Computer Speakers
Audio Technica ST90MKII Dynamic Microphone with Clip Microphone Logo
63 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Morne Olivier
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
