Question about Casio EX-V8 Digital Camera
Lens error 2
After taking the card out to print pictures off I put the card back in and when I turn it on I get lens error 2 on screen
  • Anonymous Jan 22, 2009
    dropped camera. Now shows lens error 2 but stil works
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
Lens error; restart camera
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jun 15, 2010 | Canon PowerShot SD600 Digital Camera
I keep getting error 99. I've cleaned the sensors with a new eraser; I've changed the battery and changed the memory card. If I take out the battery and put it back in, I can take a picture. If I pause for...
Hello:
Here is what Canon said :
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
I hope this will help
please don't forget to rate !
Mar 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Lens error, restart camera.
I had the same problem with my powershot and with the batteries going bad super fast. The way to fix it is to empty your memory card of all pictures then put it back in the camera blank. That should take care of the problem and should pro;long your battery life as well.
Aug 25, 2009 | Canon PowerShot A710 IS Digital Camera
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Error 99
Error 99 is an "unspecified" error. It can sometimes be due to poor communication between the lens and camera. Here are some things to try:
1) Turn the camera off. Remove the memory card. Remove the lens. Replace the lens. Turn the camera on. Replace the memory card.
2) If that doesn't fix the problem, try cleaning the contacts on the lens and camera. Turn the camera off and remove the lens. Hold the lens upside down (contacts down) and gently rub the contacts with a clean pencil eraser. Be very careful to ensure that the eraser debris falls on the table and not into the lens. Repeat with the camera body, also holding it upside down (contacts down) as you clean. Replace the lens.
If neither of these work, then you need to send the camera in to Canon for repair.
Dec 16, 2008 | Canon Digital Rebel XT / EOS 350D Digital...
Error 99 in Canon EOS 350 D
Try the following diagnosis steps, in this exact order. This will isolate the cause of the issue: -
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Dec 01, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Lens error
ok,i had this problem & couldnt find solution anywhere,so i took the back off the camera to reveal the lense unit.Now there is 2 screws in the middle of the back of the lense you need to remove together with ribbon cable.Underneath this is a small square rubber seal which was not seated properly.All i done was to seat it back in the right place,put all back together & hey presto,turned camera on & all was good.
This might not be the same problem you all have but it worked for me.
Good luck !!!
Jun 08, 2008 | Nikon COOLPIX S200 Digital Camera
Error 99 on 30D Canon
Had this problem before and i found this guide online
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
Feb 22, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
I have error 99 in my camera canon 400d
Error 99 is a general fatal error.
which includes the problems above mentioned by Q4SteveB but also many others.
It can be caused by a dicky shutter, problems with the CF card interface.
If cleaning and trying a different lens has not worked. Not definitive but as a rule of thumb...
If it letting you take one picture then giving error 99.. and the picture is saved to the card (but may just be black) this is most likely the shutter needs replacing..
If it takes a picture and gives error 99 but there is no picture on the card or the picture is 0KB its a CF interface problem.
If you get an error 99 when you plug in the USB its a USB interface error, you can try a different cable but unfortunately in most cases if another lens or cable wont work it needs repair
Feb 22, 2008 | Canon EOS 30D Body Only Digital Camera
Casio EX-V8 Digital Camera Logo
191 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
pontelemon
pontelemon
Starnley Johnwells
Starnley Johnwells
Are you a Casio Camera Expert? Answer questions, earn points and help others
