Question about JBL GTO75.4 Car Audio Amplifier
Jbl gto 75.4 right channel not working
My jbl gto 75.4 amp in my car the right channel front and back is not working
  • 57 Answers
Hi
It's rare that 2 channels will fail simultaneously, are you sending 4 signals to the amp or just 2?
If you are sending just 2, perhaps the problem lies before the amp in the cabling to it, or the output from the headunit. If you are sending 4 signals then there may be a fuse in the amp that drives 2 channels out of the 4. Of course this may be the case should you just be sending 2 signals.
Posted on Mar 28, 2009
Hi ,how can i connect my two 10 inch JBL double voice 4 ohms coils to my jbl gto 7001 amp
It is confusing with the 4 channels it gives you but you really only need to connect it to one or the other positive and negative terminals. The amps channel setup looks like this + - + - . You can connect to the first positive and negative, the second, or combine them. I had mine installed by a professional which is how I know. Also if you want to run your amp at 2 ohms then connect the subs voice coils in a parallel circuit which means that all positives are connected to each other and the same goes for the negatives. it should match the impedances of both sub and amp. Hope this helps!
Apr 13, 2011 | JBL GTO7001 Car Amp
I have the JBL gto 601.1 apm its a 2 channel, i hook them up to 2 12 kickers, the amp will play the subs properly ONLY at low volume and the amp will spit and choke on high volume ( meaning that it will go...
ok first off bbbman78 is wrong!!! second off that amp is not a 2 channel amp!!!! i have the exact same set up as u do. an i was having the same issue. i discovered that the subs were not wired to the amp correct because the amp is a class D mono amp. and it does have 2 sets of terminals to wire subs to, but it is actually a 1 channel amp! ok if u have the 2 ohm dvc (dual voice coil) wire them like in this linkhttp://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_2-ohm_mono.jpg
if u have the 4 ohm dvc wire them like in this linkhttp://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_4-ohm_mono.jpg
once u wire them correctly.....crank it up and enjoy!!
Feb 28, 2010 | JBL GTO 601.1 Car Audio Amplifier
JBL GTO 301.1ii protect mode
Hello roets81,
Check the voltage at the amp. It's possible that the voltage is either too high (above 16V) or too low (below 8.5V). Also make sure that the amp case is not grounded. If these check out OK, the most likely cause is that the amp itself is defective and requires service.
Hope this helps.
May 27, 2009 | JBL GTO 301.1 Car Audio Amplifier
JBL Sub Amp Wiring Please
it seems rather redundant to bridge a mono amp. Unless the instruction manual states otherwise, i would assume that one speaker output is identical to the other (ran in parallel, like an A or B speaker, not like Left or Right), and you would present the amp with a two ohm load by wiring one speaker to each output. Bridging it may or may not work, but, again, it just seems redundant.
Mar 01, 2008 | Car Audio & Video
Jbl gto 3501 amp
It's a mono amp. There's no bridging with this amp.
The two pairs of speaker terminals are connected together internally. The second set of terminals is for convenience.
Dec 21, 2007 | JBL BP1200.1 Car Audio Amplifier
Clarion APA5240 5 channel Amp
try this it has worked for me in the past,..Contact Clarion by e-mail .Tell them your a student and learning electronics and in need of installation ,owners manual..ask if they can help and mail you info you need.Or try this link ..Its for a APA5241 could be very similar..http://www.clarion.com/us/en/MungoBlobs/720/1016/APA5241.pdf
Dec 14, 2007 | Car Audio & Video
Bridge jbl gto 600.1
it will over heat the amp posibly blow it.....becareful
Nov 09, 2007 | Rockford Fosgate Power 1001BD Car Audio...
JBL GTO75.4 Car Audio Amplifier Logo
644 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
