Question about Canon PowerShot A70 Digital Camera
Cnaon power shot A70
My camera would not work it keeps telling me E18 and the book say when this happen it the compactflash card problem. i have try a few different ones and still it happen i can't get it to work or do any think with the camera becasue it would not stay on when this happen. Can any one help me out and should i take it to a shop to fix i wanted to give it to my son before getting a new one i am looking for a new canon D20 for myself.
Trying the tap method: Tap the padded USB cover part on a hard surface while it is power-off.
Posted on Aug 11, 2007
Check out these links: http://blogs.yucs.org/~dwallach/2004/08/canon_e18_error_repair_instruc.html http://www.e18error.com/repair.html Good luck. If you resolve my problem on how to get the housing removed, please post me the solution! CD
Posted on Jun 22, 2007
My sony cyber shot camera suddenly is saying that my Lexar 4GB CompactFlash Premium Series 80x needs to be formatted. What about my pictures?
You might have locked memory card. If not first try to connect memory card to PC with memory card reader and try to copy your stuff... then after you take all stuff try to format it.
Sep 16, 2012 | Lexar 4GB Professional Series 80x...
A Canon Power shot A70 was demagnetized.
Its known problem of CCD Imager in your Canon A70 camera and Canon will repair it free of cost.
Click Canon CCD Imager Advisory for details.
Jun 25, 2009 | Canon PowerShot A70 Digital Camera
Memory card capacity for my older canon digital camera
Does you camera use CF cards?
If so the may work but some of the newer high tech CF cards are made for newer cameras.
It may be worth a shot to try the 2GB card and if it does not work, sell to someone who uses those.
Jun 10, 2009 | Canon PowerShot A75 Digital Camera
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
Hope this helps, let me know if you have a proble.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
Cannon A70 lens stuck in middle causing it to keep powering off
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but if the camera is out of warranty they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 06, 2008 | Canon PowerShot A70 Digital Camera
Cannon power shot a70
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
Nov 24, 2007 | Canon PowerShot A70 Digital Camera
Can't take a picture or even see an image in picture mode. I get an error message E18? I am able to look at photos taken in the past.
SkiPowder, the E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Guest has a different problem. Guest's problem sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your cameras warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Oct 31, 2007 | Canon PowerShot A70 Digital Camera
Digital Camera Malfunction
mine just started doing the same thing a few weeks ago. I had downloaded pixes to the computer, went outside to take picture and it started acting up. strange lines appear on the screen, but the codes are all there, and you can view the pictures that are on the card. no, the card is not full, the batteries are fine. I think it has a virus built in to start trouble so we will go buy a new one!
May 27, 2007 | Canon PowerShot A70 Digital Camera
Lens won't open/flashes E18 on screen
i got my camera a couple of mounths, but i have not used it alot. When i turn it on, the start up screen wold come on but e18 would come up on the screen and nothing would happen after. i desperately need your help to fix my camera. thank you.
Sep 24, 2006 | Canon PowerShot A70 Digital Camera
Memory cards
You may be able to store up to 110 images if you use the camera in its lowest resolution mode. In high resolution, you may get only 24 shots. We wish we could tell you precisely, but it depends on the exact size of the file created by a given camera, as well as the resolution that you select. Keep in mind that Secure Digital, CompactFlash, and SmartMedia memory cards are competing products and are not interchangeable. You'll find a few cameras that are compatible with more than one brand, but generally when you buy a digital camera today, you'll be making a commitment to work with one type of memory card. Use the attached chart to determine the average number of photos that Secure Digital memory cards can store (compatible with most HP digital cameras)
Sep 08, 2005 | HP Photosmart 120 Digital Camera
Canon PowerShot A70 Digital Camera Logo
44 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
