Question about Microsoft Broadband Networking MN-700 Wireless-G Base Station (L21-00011) Router
Connecting Wirelessly on Accer Aspire One Notebook
I'm trying to connect my new Acer Aspire One notebook to my Microsoft MN-700 wireless router. My Acer sees the network and after entering the WEP key it tells me it can't connect to the network. Any ideas?
  • dan_conniff Dec 28, 2008
    I finally figured the problem out. The MAC address function was enabled in the software. With MAC enabled your wireless devices that are trying to connect to the router, can't, unless you've specificed there address in the MAC list. I've already setup a WEP key, so I disabled the MAC function and my laptop was able to connect to the router. Good info to know if anyone else has a similar problem.
  • eecom May 11, 2010
    Hi. One idea to start: Vista and WEP don't always 'play nicely' (and I'd guess you have Vista on your new notebook?) So, can you reset this router to run WPA encryption?
  • 30 Answers
TRY THIS:
call in your provider to change the ssid and the network key
[all computers will be disconnected]
and then try to reconnect them one by one to the new ssid or network name
this should resolve the issue
always make sure that the wireless properties are okay and the same as the router
also check the device manager: network adapters if they are properly installed and no errors on the icon for the adapters.
Posted on Sep 20, 2009
2 Suggested Answers
RickOz
  • 145 Answers
SOURCE: The driver of Microsoft MN-700 router
There is no driver required. Configuration of the router is done through your web browser. The address is 192.168.2.1. It would be best to do this via a cable connection as the wireless mode may or may not be enabled. If you do not have the users manual, here is a link to download it: http://download.microsoft.com/downlo...tion_guide.pdf
Good luck
Posted on Apr 17, 2009
We just bought an aspire one acer laptop. Trying to conect to a netgear router. Help!?
If you are trying to connect the computer to the router with a cable the above diagram should help to explain the simple broadband signal path from the Ethernet or telephone wall socket, to the router and from the router to the computer's RJ45/Ethernet port. Once the computer is connected to the router by a cable is connected to a telephone wall socket or a ERJ45/Ethernet wall socket that has a 'always on' broadband internet signal coming into it, nothing else is required -> launch the Web Browser.
If you are connecting wirelessly the wall socket to the router part of the setup is the same but no cable is required between the router and the computer.
Enable the wireless function in your netbook, click on the image of two computers bottom right near the clock -> view available networks/connect to network -> click on the appropriate Netgear router signal -> connect -> launch the Web Browser.
Nov 26, 2011 | Acer Aspire One PC Notebook
How do i set up a SSID on acer aspire 4315
> how do I setup ... on [notebook]
You don't.
You setup an SSID on a wireless router (along with password and 'WPA' encryption-level).
Then, on the notebook, you select that SSID, and enter the password, to connect (wirelessly) to the router.
Feb 20, 2011 | Acer Aspire 4315 Notebook
Acer aspire 5542 laptop won't connect wirelessly
GO TO START>NETWORK CONNECTION
CHECK WIRELESS IS THERE OR NOT
if not there
go to Start>Run type "services.msc"
start windows zero configuration
right click WIRELESS
properties
select wireless tab
put one tick mark in the use windows to configure.......................
ok
agin right click on wireless
view wireless network
search on wireless(leftside)
select connect
Nov 01, 2009 | Acer Computers & Internet
Cannot connect acer aspire one to my tp-link router
go start run type services.msc then go down to the bottom click zero wireless configuration then click start and you should be good to go
Jul 14, 2009 | Acer Aspire One A150-1672 Notebook
Caanot establish connection from MN-500 to internet
I don't think it's your router or your computers. If you just replaced your modem it has to be the problem. If it is a DSl Modem you have to imput you account username and password. If it's a cable modem you have to call the cable company and tell them you have a new modem. Which every it is you need to contact your Internet service provider, they are the ones who can help you.
Please don't forget to rate this solution.
Jun 14, 2009 | Microsoft Broadband Networking MN-500...
Wireless on/off light steadily flashes on acer aspire 3003 lci laptop and is not connecting wirelessly
Connect to your router using LAN cable to check your Internet settings.
If you can browse follow this tip link
Jan 05, 2009 | Acer Aspire 3003LCi Notebook
Can not connect wirelessly to my router.
Connect your pc back on ethernet cable
and open your browser and make change on wireless security tab (192.168.0.1 or 192.168.1.1)
under the wireless remove all security and see if that works
After if you get it connected without security then you can put back security on again
make sure the same key is on your wireless pc
http://www.networkmagic.com/nmlp/routers-b.php?src=google&kw=configure%20router&gclid=CNq0-fzq4JUCFQoHswodfHdFDw
Sep 16, 2008 | Acer Aspire 5100 Notebook
Acer Aspire wont connect to internet wirelessly.
try to change position of your wireless router it will work.
Mar 17, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 5315 with Windows Vista Home Basic will not connect wirelessly to our router but will connect to others.
hi i have just bought a Acer Aspire 5315 on vista i wanted to put it back to factory reset but it seems that they have taken out the back up to do this can i get a disc from any were or any help i would be most greatful thanks dee
Jan 07, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
202 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
